Deceleration Noise
Old Jan 20, 2014 | 01:51 PM
Mrmiata's Avatar
Default Re: Deceleration Noise
Just the way I felt.. then that new caliper did a melt down.. Just saying might want to check that line at the time you do calipers.. might end up having a good set to throw on Ebay afterwards.
Old Jan 20, 2014 | 02:32 PM
Originally Posted by Loumarino800
The presenting problem is a sticking caliper piston. I'm not going to waste time trying to clean and polish the piston and cylinder. I'd rather be driving so I'm just going to replace both front calipers with rebuilds and go from there.
Change the fluid as well, it may have a lot of moisture in it because it has never been changed.
Old Jan 20, 2014 | 03:20 PM
beasticles's Avatar
Default
I had a similar issue on my sister-in-law's Ford due to improperly mach
Old Jan 21, 2014 | 12:43 PM
Loumarino800's Avatar
OK, will check on the lines and will chg fluid as well.
Thanks again for the help
Lou
ty_ty37
Jun 27, 2024 10:42 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
pop49
Sep 30, 2015 11:14 AM
RacerXofFL
Sep 15, 2015 05:00 PM
