Problem with my crossfire
Old Feb 23, 2014 | 12:21 PM
rcross's Avatar
Default Problem with my crossfire
Thank you for adding me to the forum. I love my car,but lately it hates me. LOL!
I am having an issue with abs pump not shutting off. Even after you take out the key the pump continues to run and we have to disconnect the battery at every stop. I read that it may be the ignition switch, so we installed a new one. No change. Now the car has other symptoms now like the fuel pump wont come on and the window wiper wont turn off. I'm beginning to think its in the steering column or some relay that has something to do with all three of the issues. All help appreciated
Old Feb 23, 2014 | 12:32 PM
Default Re: Problem with my crossfire
The pump you talk of is probably the air pump on the front of the engine yes?
If so it is a sticky relay in the RCM.
Fuel pump may be a problem with the fuel pump relay in the RCM.
See this thread.
Old Feb 23, 2014 | 12:50 PM
rcross's Avatar
Where is rcm located?
Old Feb 23, 2014 | 01:11 PM
Go here.........
Old Feb 23, 2014 | 11:50 PM
rcross's Avatar
The pump I am talking about has the words abs on it and it has several metal lines going into it. It is right in front of the fusebox on the drivers side. I pulled the RCM and took a pic. Does it look like it needs soldering?
Old Feb 23, 2014 | 11:54 PM
rcross's Avatar
Old Nov 26, 2014 | 11:30 AM
slk230red's Avatar
Did you ever find out what's causing your ABS pump to keep running? I'm having the same issue on my 2001 SLK230. The diagnostics results say to replace the ABS Control Module. I'm still looking at other possible problems.
Thanks
BEATv1
Jul 16, 2015 09:40 AM
wbaker1970
Jun 17, 2015 08:57 PM
BEATv1
Jun 12, 2015 05:20 PM
MJPowers
Jun 8, 2015 02:34 AM
mouserider
Jul 17, 2003 02:45 AM
