Sell it or fix it?
Old Jul 2, 2014 | 12:57 PM
Indelibility's Avatar
Default Sell it or fix it?
Long and frustrating story made short, my mechanic told me the flywheel is bad when changing out my clutch. A new flywheel is $1,405 plus $300 in labor. Or I could sell my car and fork out the $2,000 difference I would lose on the sale. It's got 128K miles.
Thoughts?
Old Jul 2, 2014 | 01:29 PM
DTMenace's Avatar
Default Re: Sell it or fix it?
Thoughts?
Indelibility
Here's a flywheel, which is $400 cheaper, which would offset the labor costs to install the part, based upon your estimate. I would fix, then sell it.
Good Luck,
Dennis
DTMenace
2004 Mercedes-Benz SLK320 Parts - OE Discount Parts
Old Jul 2, 2014 | 01:35 PM
Originally Posted by DTMenace
Indelibility
Good Luck,
Dennis
DTMenace
I wish that were the case, I already bought an OEM spec flywheel for the SLK320, the bolt holes don't line up. Buying an OEM flywheel will give me the same issue.
I bought an LUK DMF081 flywheel for the SLK320 since the application says they're interchangeable... well it does not fit the Crossfire. I repeat to any others who may try, it does NOT fit.
Old Jul 2, 2014 | 02:04 PM
meh03's Avatar
I would think you could find a flywheel from a wrecked xfire.
Old Jul 2, 2014 | 04:28 PM
You sir, are a genius. Found a used one in good condition for $203. Guess I'm keeping it.
Old Jul 2, 2014 | 04:34 PM
Ottawa John's Avatar
The original question was to sell it or fix it. You seem to have chosen to fix it. But will you keep it? I would. With the mileage that you have the car probably won't command a big dollar, and then deducting the cost of your repair will decrease the actual return even more. And once it's fixed and you have a good running car that you must like, why sell at all?
Old Jul 2, 2014 | 05:36 PM
sk8erjosh09's Avatar
Wait wait wait!!!!
Dude, if the LUK didn't fit then you need the 05+ "CROSSFIRE" flywheel. DO NOT BUY AN SLK FLYWHEEL.
If anything man I have a C230 flywheel with the newer bolt pattern that's a tiny bit smaller but would push the V6 no problem I could sell to you on the cheap. The problem would be a clutch for it. Jim has the used one that came with the flywheel I bought.
Fu**. Jim and I were sure that the bolt pattern didn't change until 07...
Old Jul 2, 2014 | 05:51 PM
Originally Posted by sk8erjosh09
Wait wait wait!!!!
It's all good. I'm getting a used flywheel and having my mechanic install it, all for under $500.
Old Jul 2, 2014 | 05:56 PM
Default
Nah man, I'm saying you're about to buy the wrong one again. Take a straight shot picture of your LUK bolt pattern.
Old Jul 2, 2014 | 06:14 PM
I'll take the pic, but I'm getting one off a wrecked Crossfire, not an slk.
Old Jul 2, 2014 | 07:11 PM
JimmieC's Avatar
I understand there is a difference between the 04 and the 05 and later. There is a detailed "how to do clutch and flywheel"" on here some where with pictures step by step. it is close to two years old but well done.
Old Jul 2, 2014 | 07:13 PM
Here you go Josh. Odd, I ordered the DMF081 and the flywheel isn't even labeled, just says DMF...
Old Jul 8, 2014 | 10:21 AM
Sorry it took so long for me to get back, had a hell of a weekend.Looking at that bolt pattern it's the older. I'm still completely shocked why you have the updated pattern, but you need the newer style Flywheel from a newer Crossfire. I would honestly try 07+ since that's when we know for a fact the majority switched.
Old Jul 8, 2014 | 06:09 PM
That's really odd, they're shipping out the used flywheel today from another '05 Crossfire. That SHOULD fit, lol
Old Aug 26, 2014 | 10:27 AM
Goldwing's Avatar
So did the used flywheel from an '05 fit your '05?
psuperti
Feb 24, 2020 10:26 AM
northwest_crossfire
May 30, 2016 05:19 PM
bonitaeric
Aug 28, 2015 02:37 PM
Helot
Aug 15, 2015 04:19 PM
gtjl
17
Jul 22, 2015 06:28 PM
