Manual door lock issues/solutions
Old Nov 14, 2014 | 08:44 AM
drummertom's Avatar
Default Manual door lock issues/solutions
I had a hard time finding good information on how to remove the manual door lock. The procedure I did find was for a MB, and it worked, but was very time consuming. It involved removing the door panel and actually the door latch mechanism. There is an easier way, that may have been posted but I couldn't find it, and if it saves someone some time and aggravation, it's worth posting again (IMO). If your key will not unlock the door, and you don't want to wait till you have a dead battery to find this out, there is a pretty simple solution. what happens is you insert the key, it will turn but not engage anything. The problem is the T shaped link between the lock cylinder and the latch mechanism falls out. If you pull the weatherstripping on the edge of the door starting at the top, you will see a little hole. You can insert a LONG allen wrench in there, and after a bit of searching, fine the allen screw that holds the lock cylinder in. It is supposed to be a captive screw, but mine wasn't. Just unscrew it until you can feel the lock move. If if is loose enough, you can pull the door pull and the lock will come out. I would leave the allen wrench in place to kinda hold the screw in. On mine, the long T shaped piece and the roll pin had both fallen out. They were down in the bottom of the door and you should be able to retrieve them without taking the door panel off. there is a hole about the size of a silver dollar in the bottom of the door and you may be able to get them out through there. If you do have to remove the door panel, which is a PITA, there are very good write-ups on that here on how to do that. Anyway, when you find the T shaped piece aND IF YOU ARE REAL LUCKY,the roll pin, you just put the piece back in the lock and put the roll pin back through. I mushroomed the ends on mu roll pin so it shouldn't fall out again. It doesn.t matter how you put the T piece in as long as you can get the roll pin in. Putting the lock back in can be a little tricky. You HAVE to make sure it will engage the lock mechanism in the door latch, and it took me several tries, well to be honest, I got my son who is a locksmith to do it for me. Make sure the mechanical lock works and button everything up and you are good to go. Hope this helps!!
Old May 17, 2019 | 04:10 AM
Roody's Avatar
Default Re: Manual door lock issues
Hi All
Don't know if ive posted this in the correct place as could find out how to start a new post !!.
Anyway my Fob went down and tried the manual key however this inserted ok but would not turn either way !!. Ended up doing a 65Mile round trip to get spare fob and this did unlock the car. However I tried the manual key also from the spare and this done the same , would insert but again not turn either way ???
The fob that went down I gave new batteries and still wouldn't activate the locks. However I was able to do the reset sequence and now have two fobs that work, but still have the issue that the manual keys don't.
Any advice welcome.
Roody
Old May 17, 2019 | 08:05 AM
zip439's Avatar
Default Re: Manual door lock issues/solutions
First thing I would do is using your key see if you can lock/unlock the glove compartment. That way you can be certain your fob blade/key is matched to the car. There is also the passenger airbag switch on the side of the dash that is turned by the key. Not knowing the complete history of the car I would start there first.
There is a product I bought from a locksmith "HOUDINI" which I would spray into the door lock and give it plenty of time to penetrate. The old standby WD-40 would work also. Perhaps that would free up the lock.
Old May 17, 2019 | 11:26 AM
Roody's Avatar
Hi Ya
Well feel a bit daft !!! at further inspection upon applying WD 40 I thought AAAH MAYBE !!!. It turned out that because I have put chrome effect overlays on the handle (ye some would say chrome fluff ), that was protruding by about a 16th. When I pushed it in around the keyhole with one thumb and used the other hand with the key guess what the key worked. That small dimension was enough not to allow the key to fully be inserted.
So just in case anyone else has the same " fluff " on there handles then bare the above in mind, it may save you a extensive round trip to pick your spare fob up !!!
Also ive now put a set of fob batteries in glove box just in case.
Daft Roody
88stevie
19
Jan 21, 2026 01:46 PM
pioneer4x4
Mar 25, 2019 10:35 AM
JCassiW
Southeast Forum
20
Mar 3, 2019 09:43 AM
55chevy
Jul 20, 2015 03:08 PM
66L72M21
Jul 15, 2015 04:23 PM
