Gas Cap Malfunction
Old Nov 25, 2014 | 11:55 AM
Tony Palmer's Avatar
Default Gas Cap Malfunction
Can't find anything about this.
Unscrewed gas cap, pumped fuel, but was then unable to replace cap and tighten. Cap has two metal flanges and a white plastic ring - are these out of sync and won't allow me to replace and seal the fuel port.
Thanks on info on how to fix this.
Tony
Old Nov 25, 2014 | 02:44 PM
Bill F's Avatar
Default Re: Gas Cap Malfunction
Amazon.com: Gates 31849 Gas Cap: Automotive Amazon.com: Gates 31849 Gas Cap: Automotive
Old Nov 25, 2014 | 05:44 PM
with a rag grab the inside and turn the handle ,,when the two line up put the cap back on the car. it may be hard to turn but it will turn. mine did that years ago and the gas cover would not close.
Old Nov 26, 2014 | 08:36 AM
robinsonparker's Avatar
There are mainly five common malfunctions cause the check engine light to come on, and several of them are simple to fix yourself.
Replace Oxygen Sensor
Loose or Faulty Gas Cap
Replace Catalytic Convertor
Replace Mass Airflow Sensor
Replace Spark Plugs and Wires
Old Nov 27, 2014 | 01:30 PM
[QUOTE=robinsonparker;820087]There are mainly five common malfunctions cause the check engine light to come on, and several of them are simple to fix yourself.
None of the problems you state - it is just that the cap won't screw on.
Old Nov 27, 2014 | 01:45 PM
Thanks AMX 1397.
The rag didn't do anything but I raised up both metal flanges with screw drivers wedged in below and then rotated the white plastic housing to seat into the depression. That worked. Now the cap will screw on, tighten and click.
Tony Palmer
syfi
Mar 28, 2026 04:14 PM
4drturbo
21
Nov 12, 2018 04:50 PM
ritous1
Sep 26, 2015 01:27 PM
stlas69
Sep 14, 2015 06:45 PM
MickeyNasty
Sep 6, 2015 08:29 PM
