Tune up time!!!
Old Feb 4, 2021 | 06:37 PM
Mistergee's Avatar
Default Re: Tune up time!!!
Originally Posted by bc75
Check your coil packs. All 6 of mine were cracked.
would the engine show any signs of cracked coil packs, like rough idle or misfire.
Old Feb 4, 2021 | 06:44 PM
If you have rough idle or misfires, you should have some codes stored.
Have Advance or AutoZone read them out.
Old Feb 4, 2021 | 08:20 PM
bc75's Avatar
I was getting a cylinder 6 misfire. I ended up replacing vacuum lines. Had to pull intake for one of them. Then i did plugs and plug wires it ran worse than it did before. Didn't throw any codes so the only thing that was left was coil pack. I took one off seen a crack so i started checking the rest they were cracked to. Now runs like a new one.Not saying anything is wrong with yours but there easy enough to check.
Old Feb 5, 2021 | 05:21 PM
dcskmail's Avatar
I had more problems removing and installing the spark plugs than any problems with the wires . A couple of 1 1/2" wobble extensions sure help on those rear plugs
reiji
Oct 15, 2015 10:50 PM
grip grip
Other Cars Etc
Aug 1, 2015 09:18 PM
Jul 29, 2015 06:13 PM
JEFASOLD
Jul 15, 2015 02:32 PM
bradleykologek
Jul 6, 2015 02:49 PM
