'07 Coupe, 16.5k ... saw smoke in engine
Old Sep 28, 2018 | 10:00 PM
Joe_Lukeman's Avatar
Default Re: '07 Coupe, 16.5k ... saw smoke in engine
Originally Posted by Ky06coupe
I have had this problem too, on my '06. I assumed (from the greasy lower valve cover) that it was an oil leak from the upper breather cover. Research on this forum led me to that conclusion. It doesn't happen constantly, seems like only after getting on it hard. Been like that for about a year, I'm planning on getting the seals replaced soon, and will report back if that's what the issue was. I also suspect there could be steam leaking from a small crack in the seam of the coolant overflow tank. Hopefully it's not your alternator dying.
If it turns out to be the overflow tank issue that is good news as it is easily fixed. Today I just finished replacing my coolant overflow tank and I am not at all mechanical. It was pretty easy but I wanted to mention that if your springs holding the headlight bulbs are weak the time to change them or even replace the headlight bulbs is when the overflow tank has been removed from the car. Also the entire sender under the tank rotates to be removed. You do not have to un-clip the wire as instructed by the video on this site.
The overflow tank is quite strong but my old tank became weak with age and let go suddenly.
Old Jul 19, 2019 | 01:37 PM
reb's Avatar
reb
Originally Posted by ingsoc39
Hello, fired up my well maintained babied crossfire today, drove 1/4 mile to the gas station, and noticed some smoke (smelled like a burned out vaccum clean ) when I opened the hood, some light smoke was coming out of the passenger side of the engine, to the right of the fuse box, and left of the heat shield, could not see anything, opened the fuse box, nothing on fire/smoking/smell...so I dropped it off at the dealer for a quick look over, eletrical issues are a nightmare, no smoke came into the car itself....is there anything located in this are that might be a culprit? Obviously the fuse box is there, but the smoke was not coming from there..any thoughts? Thanks, care is 07 with 16.5k miles California car.
probably only oil on your exhaust manifold.check your valve covers for seepage.
Old Jul 19, 2019 | 01:42 PM
After four years, he better have it already fixed. (Always check the date of the post before you reply.)
Old Oct 24, 2019 | 02:18 PM
Sennaspirit's Avatar
What did I do today (yesterday)
I went to get my updated registration which required an inspection. While in inspection:
1) Check engine light came on when restarted in the inspection bay (it was not on prior)
2) Driver side window decided not to work
3) the hood lift failed
4) Failed inspection
Came home and took a reading - got Crankshaft and Camshaft errors.
Ordered parts, will come in 2 days,
Left key in the ignition - seeing rear spoiler in the up position this morning = "you idiot" (dead battery).
Shakes head, what a day.
Nothing too tragic, but annoying. I have a trip coming up on Saturday, I hope to have all installed and working by then.
Old Nov 25, 2019 | 05:44 PM
richb55's Avatar
Default what did you do to your Crossfire Today
Buffed our foggy headlights with great success , I decided to change the cabin filter 😱. As I removed it lots of leaves ,pine needles and just dirt .....it was a Mercedes cabin filter it looked original ... once replaced. Interior of car smelled pretty damn good
Original cabin filter
Last edited by richb55; Nov 25, 2019 at 05:52 PM. Reason: Wrong thread Should be in what did you do to your crossfire today
PNA
Nov 12, 2020 04:44 PM
northwest_crossfire
May 30, 2016 05:19 PM
Ricsoc67
Aug 6, 2015 07:56 AM
itsky
Aug 1, 2015 03:45 PM
Bayukbros
Jul 29, 2015 10:16 AM
