Oil Catch Can alternatives?
Old Feb 15, 2016 | 01:14 PM
Bowman's Avatar
Default Oil Catch Can alternatives?
I've spent hours reading about how to correct existing and/or potential problems common to our Crossfires. I think I've thoroughly reviewed the posted reasons for installing an oil catch can. Before I go to the expense and effort to install the system, I'm wondering if anyone has found other viable options for dealing with the oil residue problem. Thanks, Jim
Old Feb 15, 2016 | 02:08 PM
Default Re: Oil Catch Can alternatives?
If I was to think about it again, I would not bother to put one on the car, I have had one for some time and I have used it on two cars. I took it of the first car one day when changing the oil and thought that for the amount of oil it captured it was not worth the effort.
I put it back on my SRT and it captures some oil but if I considered this oil going through and getting burnt up it would me a minuscule amount per rev. I looked at the plenums before it went on and they were a clean as can be. Maybe with an older engine with more wear it would be better to use one, but when Valk shows the amount he captures between oil changes I somehow doubt it.
Old Feb 15, 2016 | 03:19 PM
JEFASOLD's Avatar
Here is what I did. No catch can needed! i removed the small covers on the valve covers, then I cut two pieces from a K&N filter to cover the vent holes between the valve covers and the smaller covers, coated the edges with silicon sealant, put them in place, replaced the small covers, voila! The vent tubes still work as advertised but there is no oil splash up to be picked up by the vent tubes and deposited in the intake.
Old Feb 15, 2016 | 03:46 PM
Default
Doubt all you want about the amount of oil my catch can captures over 6000 miles that I have shown in other posts
Most here know my integrity and I have no reason to mislead anyone by posting false info
Old Feb 15, 2016 | 04:06 PM
Mrmiata's Avatar
Easy big boy.. I think he means even based on what you show.. a catch can is not a "real need" on the cars...
Old Feb 15, 2016 | 05:19 PM
You got the wrong end of the stick,
read what I said again.
Sometimes I feel that I shall just quit this f'g site.
Old Feb 15, 2016 | 05:23 PM
Bravo!
Reading comprehension ***** (five gold stars)
Go to the top of the class.
Old Feb 15, 2016 | 05:40 PM
Mrmiata's Avatar
Bravo!
I do shine through at times..
Old Feb 15, 2016 | 06:48 PM
I apologize for my misinterpretation of your previous post
Old Feb 16, 2016 | 12:48 PM
kingdavid54's Avatar
Fine example of civil discourse!
Old Feb 16, 2016 | 04:59 PM
deltacrossfirebob's Avatar
I love this site.
I have found that there is a lot of very good constructive advice given here.
Onehundred80 ....I always value your input.
Although I do get a little frustrated at some of the negative comments here.
My $.02
Old Feb 16, 2016 | 10:05 PM
Bowman's Avatar
Thanks onehundred80 and JEFASOLD. I appreciate your help with my question.
Old Feb 17, 2016 | 02:03 PM
ATX SRT-6's Avatar
I've seen people use these to catch oil.
Mini Air Line Filter
boostmonkey
Feb 9, 2016 09:11 PM
AustinGSrider
Feb 6, 2016 03:16 PM
specialized1953
24
Feb 4, 2016 02:05 PM
ozkancab
Jan 24, 2016 10:28 AM
Timesnow
Jan 18, 2016 10:18 PM
