BAS/ESP light
Old Oct 20, 2017 | 03:59 PM
  #41 (permalink)
Kingdav1954's Avatar
Default Re: BAS/ESP light
The switch came in at lunch and I installed it. So far so good with a long spin around the block. Time will tell...
I took the original apart and found that one contact point was looking bad. This contact is closed when your foot is off the brake. When I get time, I am going to look over the wiring diagram.
funny how things work, 12 years and 125000 mile daily driver and mine still the original, I guess that speaks pretty good for original equipment.
Old Oct 20, 2017 | 09:52 PM
  #42 (permalink)
Ronman's Avatar
Originally Posted by JEFASOLD
If you have to replace it every year or two then you have an underlying problem that you are not fixing. I wish I had the answer for you guys but I don't. This is something that I haven't had to deal with yet.
The last one I put lasted almost two years. There is no underlying problem I am not fixing. Some people in the Mercedes forums have to change the brake light switch every year too. Every Mercedes dealership carries it in stock because it is such a common issue.
Old Oct 20, 2017 | 09:54 PM
  #43 (permalink)
Ronman's Avatar
Brake switch ordered! Will report back on the subject once installed.
Not sure what kind of code reader will work with that system.
James
The iCarsoft MB II worked for me a few months ago and it said the stop lamp was inoperable. The weird thing was the code was read from the transmission module if I am not mistaken.
Old Oct 20, 2017 | 10:07 PM
  #44 (permalink)
With that in mind, maybe the aftermarket parts are better than OEM?
  #45 (permalink)
Ronman's Avatar
Originally Posted by Kingdav1954
🤔 I was thinking the exact same thing when I read it.
When I replied it was like 5am my time. To clarify my first one lasted 7 years and went out right after my extended warranty expired. Since then I had to replace it about every year with the last one lasting about two years.
Old Oct 20, 2017 | 10:09 PM
  #46 (permalink)
Ronman's Avatar
One time I replaced it with a Chrysler one and it didn't come from Mercedes and it lasted the least amount of time. I think it is just one of those gremlins on certain cars and other cars never have this issue.
Old Oct 21, 2017 | 07:34 AM
  #47 (permalink)
😉 I think mine was built on a Wednesday haha! Assembly line was over their hangover and looking forward to their next one.
Old Oct 21, 2017 | 08:34 PM
  #48 (permalink)
After a typical day of driving the car, no light on. I think problem solved. James
Old Oct 21, 2017 | 09:03 PM
  #49 (permalink)
That's good news thanks for keeping us in the loop
Old Jan 13, 2018 | 08:03 AM
  #50 (permalink)
DHS's Avatar
DHS
Question Re: BAS/ESP light
Ok, I changed the four ABS sensors wires, bled the brakes, got a new brake light switch, still have the light on. The shop said it does have a yaw code, so is there a way to to test that without pulling it out of the car?
Old Jan 13, 2018 | 09:34 AM
  #51 (permalink)
Padgett's Avatar
Did you do the BAS/ESP reset ? (engine running in neutral, turn wheel lock to lock twice and turn key off)
Old Jan 13, 2018 | 10:22 AM
  #52 (permalink)
DHS's Avatar
DHS
OK, I just did that and the light stays on, so how had is to get to the yaw sensor?
Old Jan 13, 2018 | 10:27 AM
  #53 (permalink)
It is under the center console.
Old Apr 23, 2018 | 01:57 PM
  #54 (permalink)
sirharper's Avatar
Google for Wheeler Dealers SLK 320 and you'll see the episode where they replaced the Yaw Sensor on their SLK. Process is nearly identical for Crossfire.
Old Apr 30, 2018 | 07:52 PM
  #55 (permalink)
White Thunder's Avatar
Hey everyone ....so lm having the dreaded BAS light stay on .....so background .....stored car for the winter ....no issues no lights before storage ..so l did let the battery run down low before l noticed it , charged up and put battery tender on ...just took car out BAS LIGHT stayed on and brake pedal spongy...tryed reset with steering wheel left and right ....light still on.... shut engine off restart light off but after 2-3 brake applications comes back on ...tires pressures checked -ok ....brake lights ok.... Brake fluid level ok ..... nothing happened to cause this other than battery was almost flat.... ld almost be leaning towards replacing the master maybe trying to bleed brakes before hand ....what do you think ??
Old Apr 30, 2018 | 09:19 PM
  #56 (permalink)
Bleeding the brakes will work, until you store the car again next year. I have a new master cylinder on the work bench waiting to get some time to install. As for the BAS light, a new brake light switch solved my problem.
James
Old Apr 30, 2018 | 10:03 PM
  #57 (permalink)
James lm unclear what your saying? Bleeding brakes works temporary, master is perminant fix ...that covers the spongy pedal l get that ....brake light switch repaired the BAS LIGHT .....so your saying that they are TWO different problems. ...l thought fixing the spongy pedal would solve both problems
Old Apr 30, 2018 | 10:10 PM
  #58 (permalink)
Two separate issues for me.
Old Apr 30, 2018 | 10:27 PM
  #59 (permalink)
Ok thanks .. interesting l thought lm only dealing with only one problem.....but l guess it could be two issues then l will keep that in mind .... my brake lights work .......is that not the test for a good switch ?
Old May 11, 2018 | 01:56 PM
  #60 (permalink)
francoise1's Avatar
my air bag light stays on in the dash what do I do
