BAS/ESP light
Old May 11, 2018 | 02:15 PM
  #61 (permalink)
KDW4Him's Avatar
Default Re: BAS/ESP light
Originally Posted by francoise1
my air bag light stays on in the dash what do I do
please start a new thread with the air bag issue in the title. It gets too confusing to follow weeks down the road...
Old May 11, 2018 | 06:51 PM
  #62 (permalink)
It is nice to see the word “please” in your post, I must have missed it in the OPs post.
Requests on here often seem like demands, I do not answer them.
Old Jun 3, 2019 | 02:49 PM
  #63 (permalink)
Jdabs's Avatar
Can someone please show me a pic of where the brake light/BAS/ESP switch is exactly?
im having a hard time finding it🙏🏼
Thank you
Old Jun 3, 2019 | 06:18 PM
  #64 (permalink)
Sure thing ! :
Old Jun 3, 2019 | 10:56 PM
  #65 (permalink)
Jdabs's Avatar
No lol
the break light switch with also causes the bas/esp light coming on
Old Jun 3, 2019 | 11:48 PM
  #66 (permalink)
Thank you
It is at the top of the brake pedal lever near the pivot point, you will have to remove the panel under the drivers' side dash to see it.
Old Jun 5, 2019 | 11:50 AM
  #67 (permalink)
Bob54's Avatar
Angry Re: BAS/ESP light
Had not used the car for a week, when i did start it up, the Bas/ ESP/ABs lights came on and my spoiler came up and now stays up, I have tried disconnecting the Battery then reconnecting the battery and checked the battery with a meter, Brake lights are working, so i guess it would not be the switch, Will check the RCM next. Any one else know any thing else i can try. 2006 Straight shift. I love the car but not the Gremlins ??? Also unplugged the spoiler motor.
Old Jun 5, 2019 | 01:29 PM
  #68 (permalink)
zip439's Avatar
My brake lights were working fine, but the brake light switch did cause the BAS/ESP light to illuminate. I do not rememeber if the wing was up as well, but after replacing the brake light switch all is well.
Old Jun 5, 2019 | 02:59 PM
  #69 (permalink)
Bob54's Avatar
Thanks, I will replace it and hopfully that will take care of the lights.
Old Jun 7, 2019 | 11:26 AM
  #70 (permalink)
Bob54's Avatar
Can you give me the location for the brake light switch, Can't seem to find it. I have the straight shift. 2006 Thanks
Old Jun 7, 2019 | 11:34 AM
  #71 (permalink)
Bob54's Avatar
I see a switch on the clutch pedal, but not the brake pedal???
Old Jun 7, 2019 | 04:27 PM
  #72 (permalink)
zip439's Avatar
Read post #66 above. It is located on the brake pedal lever under the dash.
Old Sep 23, 2019 | 08:25 PM
  #73 (permalink)
XF61's Avatar
I realized I never replied to any of these answers! I just wanted to thank you because it worked!
Old Jul 10, 2023 | 07:32 PM
  #74 (permalink)
MyrtleB's Avatar
I was waiting for him to answer too! 👍🏻
Old Jul 30, 2023 | 02:41 PM
  #75 (permalink)
adoni's Avatar
Good afternoon from Southeast Tennessee!!
I too have had the BAS / ESP light on and the "light out" lamp lit at various times. I'd start the XF, no lights, press the brake pedal, lights came on. Somewhere else on the forum I read that the owner was wiggling fuses while his son pressed the brake pedal. Fuse #2, located in the fuse box in the dash, was the culprit. I too replaced the brake switch, not too difficult BUT, I'm not as young as I use to be trying crawl under the dash. That didn't fix my problem. So I played with fuse #2. Didn't need to change the fuse, I removed it, rotated it 180 degrees and reinserted. No more warning lights on dash, brake lights illuminate and cruise control works.
As I was looking at the fuse to see if it was shorted out, I noticed that the fuse and the connectors in the box are aluminum. Aluminum is an awesome conductor, it's lightweight and inexpensive. BUT ...
As an engineer at Caterpillar we had very large testing stations that would cycle the components after manufacturing as if it was installed in a machine. These stations had very large pumps and motors attached to test the component. Many were 400A motors. One test station was being repaired and it took a while. The main feed for the machine was connected to a 2400A aluminum main buss. As the machine sat, the aluminum cooled and the main connections were not tight anymore, no one checked them. I was doing field work, near the machine, and the electrical cabinets were on the mezzanine approx. 13 feet above me. When maintenance fired the machine back up, the connections being loose arced and a 4 foot fireball shot across the room, over my head. The loud bang was close to a cannon sound.
Bottom line to that whole long story, aluminum is great but. My XF will be 20 years old in Sept of 2023, and those aluminum fuses have been pretty much undisturbed. They'd heat up, then cool down. It is highly possible connections aren't quite as tight as they were when the XF was manufactured. To date, I've removed and reinserted fuse #2 (BAS/ESP brake light) & fuse #9 (remote fob not unlocking doors). All works fine now. I haven't touched any other fuses but, I think that will be the first thing I do should I have any other issues.
Just thought I'd share.
