Gear selector is moving... AGAIN
Old Feb 6, 2018 | 12:44 PM
AtomicBubbles's Avatar
Default Gear selector is moving... AGAIN
Well as the title says we know what that usually means.. I broke another motor mount.. for the 3rd time..
So I've tried doing the cable method using I believe 1/8" cable and some ties and wrapped it maybe 4 times around the driver side motor mount and used some of those cable locking bolt loop deals.
I've looked under the car momentarily just the see any visuals and the cable is actually severed like the engine's torque was actually able to stretch and shear the cable... I probably in hindsight I may have had them too tight.
Anyway the only other methods that i have been able to find using this forum and other car forums is either "chaining" the engine down (sounds like a PITA) or I think one time I found a picture of someone that had some sort of "Bar" that went across from the right shock tower mount and bolted into the superchargers lift holes and continued to the passenger shock tower mount.
Maybe with some bushings in place would still allow some flex but keep it rigid.
Replacing these motor mounts are a HUGE PITA!!
ALSO I've used the search and cannot find a how to on replacing the TRANS mount. everyone always talks about the motor mounts.
Anyway thanks! hopefully will get a solution to this annoying problem
-Darren
Old Feb 6, 2018 | 01:32 PM
Default Re: Gear selector is moving... AGAIN
SRT or NA, Stick or Automatic, Modifications ????
Old Feb 6, 2018 | 01:42 PM
If it has a supercharger its SRT and Automatic obviously haha and Ive got 64mm pulley and Dyno tune right now.
Old Feb 6, 2018 | 03:20 PM
Padgett's Avatar
Most OEM mounts are captive after the GM debacle in the late 60s. Are these OEM ?
Old Feb 6, 2018 | 03:51 PM
they are the OEM style mounts that are liquid filled. Got under car breifly before I have to go to work. It seems the mounts aren’t leaking and I don’t see any obvious abnormalities.
Next thing to to check I think would be the trans mount and the flex discs on the drive shaft... not sure if those would cause engine movement but maybe.
eagle670
Nov 27, 2014 08:33 AM
eagle670
Nov 25, 2014 01:07 PM
eagle670
Nov 17, 2014 04:10 PM
Billy22Bob
Dec 24, 2013 12:09 PM
waldig
Sep 28, 2012 02:16 PM
