Electrical problems
Old Mar 8, 2018 | 07:38 PM
Weamshoff's Avatar
Default Electrical problems
Has anyone had this problem? I was driving my 2007 Crossfire last week when my radio kept cutting on and off. I didn’t think much about it till it was doing it again the next time I took it out. I didn’t even make it 1 mile when the radio started rapidly going on and off then the engine started spitting and sputtering. Finally the car stalled and appeared to be completely dead electrically. I turned the key off and back on and it appeared that everything was ok. The car restarted and I took it straight home. I have a year old battery and only have 30,000 miles on vehicle. I’m afraid I’m going to get stranded somewhere if I don’t get this figured out.
Old Mar 8, 2018 | 08:53 PM
Steve Jr's Avatar
Default Re: Electrical problems
#1: Crankshaft positioning sensor( replaceable)
#2: RCM, relay control module ( fixable)
Old Mar 8, 2018 | 08:57 PM
Weamshoff's Avatar
Thank you Steve!
Old Mar 8, 2018 | 11:37 PM
What about bad battery connection?
Old Mar 8, 2018 | 11:57 PM
Along with the poor ground circuit from the factory.
Old Mar 9, 2018 | 07:00 AM
Or the battery itself may have an intermittent open in one of the cells.
Old Apr 22, 2018 | 08:55 PM
Weamshoff's Avatar
It turned out that is was a bad battery. I did wind up getting stranded and calling a tow truck. I got it home and took the battery ( which was 6 months old) back to Advance Autoparts where I bought it. They tested it and said it was perfect. Then I took it to the dealer. They said it sounded like a bad battery. I told them it was only 6 months old and was tested twice not to mention that it quit while it was already running. It took 2 weeks for the dealer to determine that it was indeed the battery and it had a small crack and a short in it. After a lot of complaining to Advance Autoparts I finally got them to give me a new battery. If they would have found the bad battery during one of their “tests” it would have saved me $160 labor and $80 towing. Fooled me too because I never knew a car could quit running from a bad battery while you were driving it. Thanks everyone for your advice. A couple of you called it as a bad battery.
Old Apr 22, 2018 | 09:51 PM
Glad it finally worked out for you. Sometimes you can file a labor claim with the store with proof of a defective item that they claim otherwise. Explain your situation with the store manager. The worst he can say is no.
James
Old Apr 22, 2018 | 10:00 PM
Weamshoff's Avatar
Thanks James, I was so happy that’s all it was that I will probably just let it go. I was prepared to hear that it needed a new computer or something. I couldn’t imagine what that would cost. Thanks for your help.
blackcrossfire07
Feb 25, 2009 02:57 PM
conkeeper
Jul 17, 2008 11:38 AM
allmyn
Jun 2, 2008 04:41 PM
ALady
Dec 11, 2007 04:34 PM
CrossFireBabe
20
Mar 6, 2007 07:27 PM
