Base seating questions
Old Sep 3, 2018 | 08:15 PM
Default Base seating questions
My Base seats in my Roadster do not sit even with each other. The driver's side sits nearly 3" taller than the passenger seat. Is that normal for other Base owners?
Also the driver's seat has an adjustment lever on the outboard side. Pulling it up does nothing but I can feel it is hooked to something. The owner's manual only covers the Limited seats.
Any info would be appreciated. James
Old Sep 3, 2018 | 08:33 PM
Default Re: Base seating questions
The lever on the side, if you 'pump' it, lowers the seat. I lowered mine all the way and left it there.
Not sure how you raise the seat, I assume you get out and manipulate that lever and pull the seat up.
The **** on the back moves the back forward and backward.
The lever down in front is the release for you to move the seat forward and backward.
shapeshifter309
Mar 27, 2010 08:16 PM
p69firebrd
Nov 23, 2008 05:26 AM
andrew
Aug 7, 2004 11:21 AM
andrew
Apr 20, 2004 04:36 PM
pete1365
Dec 9, 2003 08:18 PM
