Do XF engine and motor numbers match?
Old Jan 24, 2019 | 09:49 PM
tinkerer's Avatar
Default Do XF engine and motor numbers match?
Happy New Year! I did a couple of searches on this forum and on Google, and couldn't get confirmation if the Crossfire's engine number and VIN are supposed to match. I saw one article that said the number is on the back of the engine on the right (assuming driver?) side of the car. Another one said they won't match because it is a Mercedes engine. Please advise!
Thanks,
Terry
Old Jan 25, 2019 | 09:52 AM
Default Re: Do XF engine and motor numbers match?
The "engine number"??? If you are asking "can I put the engine from another crossfire in my car without changing the computer crap?", then the answer is this:
If you are not changing from N/A (Limited, Base) to SRT (with supercharger), then there is no concern. An M112 engine, in an M112 engine - the ECM only knows what's going on based on sensor inputs from the engine - not on any serial number/VIN interface.
Old Jan 25, 2019 | 09:26 PM
tinkerer's Avatar
Thanks Pizzaguy. I should clarify. I am still searching for a car. It's not a good time to test drive a convertible in the upper midwest. :-) My previous experience comes from motorcycles and older cars (Buick and Pontiac) where the vehicle is worth less if the engine and frame numbers do not match, implying a replacement engine was installed at one time. Is this something I should look at with these cars? If they don't match from the factory, it's not an issue!
Terry
Old Jan 26, 2019 | 11:24 AM
Anyone who has changed an engine in one of these cars, has put a V8 in there.
The M112 is really solid, I've lost count of how many of us are past 200,000 miles and I know of two that are past 300,000 miles - with original timing chains, even.
Old Jan 26, 2019 | 11:39 AM
Anyone who has the original chains at that mileage is asking for serious trouble. Many of these cars have had parts changed unknown to the current owner.
Once the chain starts jumping gear teeth or breaking you are in for a quick lesson on major engine repair.
Old Jan 26, 2019 | 12:02 PM
JSK's Avatar
JSK
In the early 90s I had an 87 450 SEL. AT 90 some thousand miles the plastic tensioners on the timing chain came apart and the pieces got in between the sprockets and the chain. Several valves got bent and had to replace the heads. Arizona is a great environment for bodies but not so great on plastic parts.
Old Jan 26, 2019 | 12:15 PM
You mean parts that see the sun.
I was in Atlanta and I was talking about cars to a customer, I said our Canadian cars suffered body rust and he said their interiors went to hell. Out of two ten year old cars we could make one good car. 😀
rmcdaniel12
Aug 31, 2015 11:53 AM
tburris
Aug 23, 2009 08:45 PM
SilverFox
Dec 3, 2007 01:19 PM
Scott_lmtd
Sep 22, 2005 07:40 PM
Danwell
May 19, 2004 03:23 PM
