Air Ram Intake/mods required?
Old Mar 7, 2007 | 01:32 PM
Romio's Avatar
Default Air Ram Intake/mods required?
I read alot of posts about intakes, and I can't see myself getting a custom cold air, so I decided to go with the dual ram intake. I know most people say they aren't worth it, it breaths hot air and all. but I also seen a few people removed the covers behind the grille. So my question is. What is the best (low cost, work good), intake I should get, there is 2 sets on eBay, but they look pretty dinky. Not looking to spend too much. I heard some people got them for $80. Also if anyone has any instructions or tips on removing the existing covers for the intake now. Thanks in advanced for any help.
Old Mar 7, 2007 | 04:14 PM
spensley's Avatar
Default Re: Air Ram Intake/mods required?
There are 2 flexible pipes from the air filter housing/box to the air intake piece behind the grill.
These pipes just simply pull out.
The pieces immediately behind the grill are held in by a couple of screws. the RH side is easy to remove - the LH side is trapped by a pipe (cooling I think), there's a screw which holds that secure, if you remove the screw the pipe flexes and you can remove the front portion of the air intake.
Old Mar 8, 2007 | 09:45 AM
Romio's Avatar
ok, so its possible to remove both sides without removing the radiator?
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
Sep 28, 2015 07:40 PM
rfourt
Sep 25, 2015 01:38 PM
