Stock HU with Aftermarket Amp
Old May 6, 2007 | 10:09 PM
RichardClark's Avatar
Default Stock HU with Aftermarket Amp
I bought the Pioneer GM-5300T (http://www.crutchfield.com/S-VmqOdQb...p?i=130GM5300T) a few days ago from a local retailer and was wondering if it would work with the stock HU and speakers? If I understand correctly the stock speakers are 2 ohms. The Pioneer amp produces 190 watts RMS x 2 at 2 ohms. How many watts can the stock components accept without blowing? Has anyone experimented with this setup or one similar to it?
Thanks,
Richard Clark
Old May 9, 2007 | 01:05 AM
minojo's Avatar
Default Re: Stock HU with Aftermarket Amp
I was wondering also how the set-up will be 'cause I wanted to keep my nav/head unit and install aftermarket amps and subs in the trunk.
Any good input is greatly appreciated!
Old May 9, 2007 | 12:25 PM
Infinity's Avatar
If you are feeding the head unit into the factory amplifier nothing changes ... other than you are sending the factory amp a higher level than original which will mean it will get louder faster and trip the limiters sooner.
If you bypass the amp and use the deck power it will be fine, I run over 100 watts from an off board amp to the factory set with no issues for two years now.
Old May 10, 2007 | 12:40 PM
If I was going to bypass the factory amp for just the front L/R which wires would I have to cut and direct to the new amp while still leaving the subs powered by the stock amp?
here is the wiring diagram
https://www.crossfireforum.org/forum...80&d=113688095
Thanks,
Richard Clark
Old May 10, 2007 | 02:18 PM
Infinity's Avatar
7 8 16 17 are your door speaker wires, you will still need to provide a high level signal from the head unit to the factory amp.
TerryR
Dec 13, 2019 03:27 PM
Sterling57
Apr 11, 2016 06:11 PM
rmcdaniel12
Nov 4, 2015 04:08 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
Sep 28, 2015 07:40 PM
