Upgrading base sound system
Old Sep 4, 2007 | 11:04 PM
jhb's Avatar
jhb
Default Upgrading base sound system
By way of background, this is my first post following a purchase of a "new" 2005 base coupe earlier in the month. (I always liked the black on black look.)
The dealer facilitated an install of Katzkin leather seats for $699. They look good - kept them dark for a stock look.
I'm now thinking about what it would take to upgrade to the limited sound system. Is this possible through trolling car-part.com or ebay for a wrecked car part? What components would I have to worry about - receiver, amp, speakers I trust? Will the faceplate fit in the current opening? Will the speakers fit in the current openings?
I'd be interested to hear if anybody out there has solved these questions.
The car is a hoot.
Old Sep 4, 2007 | 11:07 PM
RPM's Avatar
RPM
Moderator
Default Re: Upgrading base sound system
I am no car stereo guru, but I will welcome you to the forum - congrats on your purchase and welcome - .
Old Sep 4, 2007 | 11:20 PM
Sidez's Avatar
lets see those seats and welcome to the forums.
Old Sep 4, 2007 | 11:21 PM
jhb's Avatar
jhb
I know, I owe some pics on this. Will post soon.
Old Sep 4, 2007 | 11:42 PM
RMADERMAN's Avatar
Not a stereo person, but I changed my stock stereo for a Kenwood. It is 1,000% better. Could hardly hear the Infinity with the top down going 70...80...90... Now the guy or girl I am passing can sing to my stereo. I am exaggerating somewhat, but you get the point.
Of course my daughter wants one too. Not going to happen unless she pays for it.
Old Sep 17, 2007 | 10:49 PM
RBeatz's Avatar
Buy aftermarket, if you put the money into "upgrading" into a better factory system you'll have blown more money than it would have to build a killer one with aftermarket stuff. Trust me.
Old Sep 18, 2007 | 10:26 PM
palexfire's Avatar
i have the infinity system in the coupe... it sucks...i just changed it today to a better infinity component system..its was a pain in the but to install but way better... they say they give you infinity speakers and they do but the quality of the stock speakers very poor...the highs go down when a you play a song with a lot of base... you should just go aftermarket all the way 6 1/2 will fit perfect for both the front and rear...it all looks stock with much better sound...
Old Sep 19, 2007 | 05:14 AM
radmanly's Avatar
Now that you've had the opportunity to compare stock and aftermarket Infinity speakers, can you tell us what makes the stock speakers subpar? Is it the materials quality, the quality of the electronics, what?
Old Sep 19, 2007 | 05:43 AM
acrispy1's Avatar
I did this and the sound is 100% better coast me $11, check it out.
https://www.crossfireforum.org/forum...ead.php?t=9938
Old Sep 19, 2007 | 07:49 AM
spensley's Avatar
This topic has been covered previously.
Do what 'acripsy1' posted - I've done it and it does make a great deal of difference.
I believe that the base model does not have the rear speakers - directly behind the seats - this was discussed in the earlier topic.
Try and search for the earlier thread, I believe it mentions that the holes are already existing for the speakers.
Old Sep 19, 2007 | 08:03 AM
DanielNTX's Avatar
I'm going to have to disagree with you about the stock speakers in the '04 and the limited. I think they are of good quality. That's why I kept them. I concur with Eracer76's findings in his post: Stock front speakers rock! and he is a professional stereo installer.
Being that I'm an installer, I've tired some things like the capacitor trick. I found that I didn't like it, I don't know what some people are hearing. After I put the capacitors on the front speakers, I realized just how bad the factory subs sound and the overall bass output was far less. The front speakers actually are very good and don't distort as bad as the subs do. So I removed the caps for the time being, until...
I knew I was going to add a aftermarket amp because I just wasn't satisfied with the not so clean and not so powerful factory amp.
So, I changed the head unit for my Pioneer and added my JL Audio 500/5 five channel amp which is 100x2 for the front, 25x2 for the rear, and 250x1 for a sub. I removed the door panels to run my wires to the speakers, and realized how nice the front speakers actually are. They are NOT your typical factory speakers, like the old Chrysler/Infinity speakers. These speakers are true Infinity speakers with Polypropylene cones, rubber surrounds and a huge magnet. The tweeters are a nice dome style unit that is actually positioned good, pointing up towards the rear view mirror which I didn't know before.
So...I just amplified the stock front speakers with clean 100x2 power with the amps crossover set at about 63hz and they sound great!
The stock front speakers produce alot more, cleaner bass then the stock subs do. I left the stock subs hooked up to the factory amp, on the rear outputs of the head unit, that way I can use the fader to shut them off if I want to.
I love the sound Im getting from the stock door speakers now, very loud, clear and lots of mid bass that you can feel on your legs!
The rear 25x2 outputs of my JL amp are not being used for the time being, some day I may use it for the stock subs for some fill, because...
I added a JL audio 8W7 8" sub in a sealed box using the 250x1 from the amp for some real bass that moves the hair on my head if I want it to!
Old Sep 19, 2007 | 12:08 PM
radmanly's Avatar
I remembered reading Eracer76's post which is why I asked palexfire what he thought was so bad about the stock speakers.
Old Sep 19, 2007 | 03:34 PM
palexfire's Avatar
yes you are right the front speakers are really good... its the subs in the rear that suck. i purchased all of the speakers so i took the front ones out too. the crossover in the component system helps a lot. i wanted to keep everything stock witch is why i bought infinity aftermarket. but the infinity stereo sucks. so i'm looking to change that in the near future but i get a better sound out of this new setup. its a lot louder cleaner crisp sound. i like the sound before the only problem i had was that the highs went down when the base in the song would hit then the high would come back up again i just didn't like the sound...
Old Sep 19, 2007 | 05:42 PM
porterhouse's Avatar
I had the same '05 base coupe. Only thing I did to improve the sound was change the headunit. Pioneer in my case.(see my gallery). I hooked it up to the stock infinity amplifier and stock speakers and it sounded good. I also added ipod and sirius. Now if you want more bass, you have ot get the separate amps/subs...etc. Good luck.
Old Sep 19, 2007 | 10:51 PM
RBeatz's Avatar
The poor quality actually has very little to do with the speakers themselves. It's the DSP processor that is built into the system. It turns up the bass at low volumes and down at high to compensate for road noise among other things just like a lot of factory systems out there.
Old Sep 23, 2007 | 10:44 PM
JonZoidberg's Avatar
I've only had the car for 2 weeks but I've been researching the radio nonstop so I'm wanting to move on and get to enjoying the drive, not fumbling with CDs.
I want to do the bass blocker mod. Absolutely will. I wondered during the test drive if the subs were in the doors. Keep the bass to the subs, please.
However, I do want several things:
Stock or Semi-stock look
Bluetooth - I make calls in my car everyday and it's just not safe or comfortable.
Ipod integration - CD fumbling sucks, and stock player won't read my burned CDs. Don't want a HU with no CD though. The medium hasn't gone all 8-Tracky yet.
Navigation - sorta kinda, the car came with it, and I was excited to get it, and now to cast it aside, sucks, even though it's probably not the best. Not a deal breaker.
So, I looked into my options -
Stock headunit - I can get the Denison IceLink, as outlined in another thread, it looks to cost me $189 shipped, after coupon. Not exactly Ipod Control, but good enough with the 5 playlist options.
As for Bluetooth, most people here recommend the Motorola IHF-1000. $169-200, by most accounts. Ebay maybe cheaper, but due to some complaints I might want to actually have a store to return it to. $169 from Amazon with free ship. ~ $20 for the wiring adapter from Becker NA.
So stock head with Ipod sorta kinda, and Bluetooth for around $400. Also, anyone used the Moto HF850? What are the big differences? The price is less than half and looks pretty much the same.
I narrowed down the aftermarket options to 2- the Sony MEX-BT5000, looks pretty good, $329, and has BT built in, and can add Ipod Full Integration for about $50. So, I'm looking at $400 again, except I lose the navi. And that big copper button? Where does that look stock?
Pioneer's DEH-P880PRS is cool, and looks closer to stock. Also, probably a better sound. Dunno, haven't heard it. However, nothing is built in to this $400+ unit, and BT is $200, and Ipod another $50-60. So now we're climbing to $650. Dunno where I'd put all those add in units either. They look big in pictures.
Seems a shame to spend $400 and not even get a new radio, but I don't know. Thoughts? I'm no audiophile, I just want to be hands free and have access to all my music without the fuss. Hell, I'm no Ipod junkie, I'd have to buy one to add it to the system.
Bonus - I'd like a remote for the steering wheel. The sony one looks like a torture device, a little twisty **** of doom that needs it's own manual. Pioneer looks to make a smart looking one that clips to the steering wheel, reminds me of my Acura TL's. I'd settle for just volume controls, and track skip, like the TL.
I will move on this soon, and post pics of the process, as I will install myself. Please let me know what you think! Aftermarket, or fool with the stock? Also, any words on the Motorola 850 vs 1000?
PimpDaddy
Sep 29, 2016 11:55 PM
Helot
Aug 15, 2015 04:19 PM
IsaacF
Aug 13, 2015 07:01 PM
Jerrysrt6
Jul 24, 2015 09:15 PM
Rusty475
Jul 13, 2015 10:03 AM
