Cost to Remove Tint?
Old Mar 17, 2008 | 07:41 AM
ravenous's Avatar
Default Cost to Remove Tint?
Does anyone know how much it SHOULD be to remove tint in just the front two windows? All windows? All windows and retint just the back three? I'm in sacramento, ca.
Old Mar 17, 2008 | 08:06 AM
robby363's Avatar
Default Re: Cost to Remove Tint?
You could do it yourself it's not that hard. If you start at the top corner with a razor blade scrape enough to pull it. Once you get it started you can peel most of it off in one big piece just take your time and go nice slow you might have to scrape it little as you doing it. After you get it off clean the class with adhesive remover if needed and then with a good glass cleaner. I've had to do it on a couple of cars I've owned.
Old Mar 17, 2008 | 08:08 AM
ravenous's Avatar
I've thought of using adhesive remover if I did it myself...but I am worried I might mess up the glass - Will I?
I am also worried about scratching the glass with the razor blade....am I just being a *****?
Old Mar 17, 2008 | 08:16 AM
makeithappen's Avatar
if you keep the razorblade as parallel to the glass as possible while you scrape you will not hurt the glass. at the place i got my tint done they take it off for free. it only takes like 3 seconds.
Old Mar 17, 2008 | 08:19 AM
robby363's Avatar
If your careful and take your time you won't scratch it. You should be able to peel most of it off with out having to scrape it off.
Old Mar 17, 2008 | 07:23 PM
tttosrt6's Avatar
How dark was your tint and what kind of crossfire do you have? as you can see I also live in SAC so I am very interested in what cops do around here since I wanna tint my windows...
Old Mar 18, 2008 | 06:15 AM
ravenous's Avatar
5% all around on a 04 light blue/silverish coupe.
I removed the tint from the fronts....it still looks good but not as good....
I suppose the good thing though is that I can see outside from my front windows at night now...
Old Mar 18, 2008 | 11:27 AM
tttosrt6's Avatar
thanks a lot... i might just think again before tinting...
4drturbo
21
Nov 12, 2018 04:50 PM
RamblinShamblin
Aug 12, 2017 10:55 PM
smokey847
Nov 12, 2015 11:54 PM
55chevy
Sep 13, 2015 07:38 PM
jaesa
Sep 7, 2015 01:50 PM
