How do I get to the two bolts on t-stat?
Old Apr 3, 2008 | 09:51 AM
ws6vert's Avatar
Default How do I get to the two bolts on t-stat?
I did a search on replaing the thermostat and all I could find was ,it's easy just two bolts. well I see the two bolts and they dont look easy to get to. A pulley is in the way and I cant even find a tensioner to get the belt off to take the pulley off.!!!
Old Apr 3, 2008 | 12:39 PM
Alabaster04's Avatar
Default Re: How do I get to the two bolts on t-stat?
I just recently changed out my Thermmostat, but it was on a N/A coupe. So I think there are a few more obstructions in the way for you to remove the stock unit. I did not have to remove the belt or anything, just used a 3'' extension on an 8mm socket and they came right off, of course I don't have a Supercharger in my way That is a problem I wish I had. But all I did was remove the plastic engine cover and I was able to acces the bolts.
Old Apr 3, 2008 | 01:33 PM
ws6vert's Avatar
Yeah its all s/c pulleys in the way. So the belt has to come off to take the pulley off but I cant find a tensioner.............
Old Apr 5, 2008 | 04:08 PM
crossfirefun's Avatar
Here is a pic copied from another thread here: Looks like pulley number three must have something.
Old Apr 5, 2008 | 09:36 PM
Moparrbust's Avatar
I just did my t-stat on the 6 this afternoon. I removed the two clips and one plug in on the fan assy. and removed it. Then I use my inverted torx E10 to loosen the tensioner and remove the serpentine belt from the idler pulley near the t-stat. I then removed the idler pulley by unbolting the 16mm bolt. Then you have clear access to the two E10 bolts on the thermostat.
Old Apr 5, 2008 | 11:10 PM
cruzinquick's Avatar
If you ordered the pulley from Needswings he includes the socket you need for the tensioner.
syfi
Mar 28, 2026 04:14 PM
Nov 11, 2015 05:22 AM
Oct 1, 2015 01:42 AM
Sep 26, 2015 10:21 PM
Sep 25, 2015 07:46 AM
