New Kenwood PNAV-512 Installed - No AM Reception
Old May 7, 2008 | 08:05 PM
rcompart's Avatar
Default New Kenwood PNAV-512 Installed - No AM Reception
I just installed the new Kenwood PNAV-512 Nav/DVD which consists of the KVT-512 and the KNA-G510. Installation was super easy as and it took about 3 hours from start to finish. This was partly due to the fact that I fitted everything twice just to make sure. I installed the GPS module under the passenger side carpet where the foam is. It's the exact same height as the foam and so I just cut out a square, taped the foam with stick tape so it didn't bead up under there from vibration and ran the wires along the plastic bottom part of the center console. If you take the floor vent and screw out of the vent on the passenger side, you have plenty of room to fit your hand in there to manuever wires. Like I said, the install went good but now I have absolutely no AM reception. I had great AM reception with my other radio so I don't get it. I searched for "AM reception" and "am radio" but the word "AM" is too short so it gets ignored. Anyone have any advice? I know I'm too young to be listening to the AM dial in the morning but I need my WCCO for anyone that lives in MN and it's drving me nuts right now knowing that tomorrow morning, I'm gonna have to listen to the half @$$ed morning show because I can't get any AM reception.
Also, I have two pictures of the install. Phone battery died after I took the first two so when I'll put the rest up tomorrow. Looks pretty good. Gonna have Q2 Designs paint it cilver to match the rest of the interior but it's low on my list of priorities at the moment.
Old May 8, 2008 | 07:24 AM
eganders's Avatar
Default Re: New Kenwood PNAV-512 Installed - No AM Reception
Are you sure the antenna for the car, that used to be plugged into your old radio, is solidly plugged into the KVT-512? The antenna that comes out of the KNA-G510 is for GPS only.
Old May 8, 2008 | 07:42 AM
rcompart's Avatar
Yes, the antenna is firmly connected and put heat shrink tubing on every connection so that nothing would vibrate loose. I tore into it twice just to make sure that I did indeed have everything connected and didn't overlook anything and it all looks good. Also noticed that my FM reception, although not terrible is worse than with the stock unit. Is there an antenna booster that I would need to install since the coupes don't have an actual aerial antenna but rather it being in the rear window? I'm perplexed as I have installed lots of A/V equipment in my friends and my cars over the past 10-11 years and never once had anything like this happen.
Thanks in advance.
Old May 8, 2008 | 09:13 AM
nascarhq's Avatar
Thanks in advance.
hi, ive got the kenwood nav setup too.i had to have the euro/vw antenna adapter,my reception is excellent.if you already have that,i dont really know any other solutions.
Old May 9, 2008 | 05:49 AM
macca30's Avatar
I have a KVT M700 and have the same problem, FM is ok no AM at all, anybody got any suggestions please. Im missing talk sport.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
