XM Antenna Placement
Old May 10, 2008 | 10:13 PM
brain_26's Avatar
Default XM Antenna Placement
I just recently bought the XM XPRESSRC, and I had no problem installing it via my factory car stereo. Although the XM antenna is being a nuisance, I ran it outside and installed the antenna between the bottom of the windshield wipers. As I am driving around, the signal drops and especially when I make turns.
I do not want to place the antenna on top of the vehicle since it looks like a pimple on the roof. I tried sticking scotch tape temporarily on top of the antenna and sticking it right under the brake light of the hatch window (inside of the car), but still it did not work well. I do not know if the tint is getting in the way.
Does any one have any suggestions on mounting the XM antenna? If you have pictures please share them with me since it helps with the process.
Old May 11, 2008 | 02:30 AM
Mr. F's Avatar
Default Re: XM Antenna Placement
i mounted my Sirius antenna to the very top edge of the rear glass. used 3M molding tape. clean the window really good first, and stick the tape to the antenna first. i used a couple strips and trimmed it to fit perfectly.
tried to pull the antenna off and it doesn't want to budge at all.
i'd take a pic but it's still dark...
Old May 11, 2008 | 05:24 AM
brain_26's Avatar
If you can take a picture at your convenience, it will help to have a visual. Have you had any problems with your signal?
Old May 11, 2008 | 07:06 AM
Mr. F's Avatar
nope. no signal problems with any of my vehicles, and one of them i shortened the antenna wire even though the Sirius people say "OMG don't do that!!!!"
Old May 11, 2008 | 08:09 AM
brain_26's Avatar
Awesome, thanks for posting those pictures. When you see a picture it makes a big difference. I will move mine to the back window, and I will see if it works.
Old May 11, 2008 | 08:38 AM
Mr. F's Avatar
with the center spine there's nowhere to put it on the roof...and there was no metal to stick it to below the window. i know they say the antenna uses the metal as a ground plane but i haven't had problems. went to Toronto and back and never lost signal.
Old Jun 8, 2008 | 07:39 AM
brain_26's Avatar
Here are the pics of the complete install of my XM unit.
Other pics are located via this link https://www.crossfireforum.org/forum...ad.php?t=24642
Old Jul 5, 2009 | 10:10 AM
Rich W's Avatar
OK, any suggestions for those of us with roadsters? Will it receive signals through the soft top? I'm thinking about placing the antenna between the roll bar hoops?
Rich
Old Jul 5, 2009 | 01:00 PM
Mr. F's Avatar
on my Wrangler the antenna is mounted to the top of the sound bar, which is covered with fabric. i have no problems getting a signal with either the soft top or the hard top installed.
woodlands1
Nov 22, 2023 10:48 PM
ritous1
Sep 26, 2015 01:27 PM
Boresite
Aug 9, 2015 10:33 AM
GatorLCA
Sep 29, 2007 09:39 AM
gibsonjunkie
Sep 8, 2006 10:13 PM
