will i run lean with an ecu tune?
Old May 29, 2008 | 08:55 AM
HyprLtH20's Avatar
www.CustomCrossfire.com
Default will i run lean with an ecu tune?
will i be running lean if i get an ecu tune with my current mods? i have intake, exhaust, plugs, and wires. i have read somewhere on here that if you get a tune without new injectors you will be running lean.. is this the truth?
Old May 29, 2008 | 09:16 AM
spensley's Avatar
Default Re: will i run lean with an ecu tune?
I think you're correct.
I don't think just new injectors will solve your problem - I think you still need the ECU tune to squirt more fuel through the injectors so you don't run lean.
TVT wrote all about this - either search or contact them directly would be my suggestion.
Old May 29, 2008 | 09:46 AM
Mimi05SRT6's Avatar
The purpose of a tune is to have your air/fuel where it should be with the mods that was specified. That's the whole purpose of a tune to prevent from running lean.
Old May 29, 2008 | 11:31 AM
Maxwell's Avatar
your currently running lean with out an ecu tune
Old May 29, 2008 | 12:01 PM
Floaten621's Avatar
well that can go both ways. because if you were to stick bigger injectors in with out a tune they would still be pulsing at that set duty cycle. which means you most likely would be running pig ritch. An intake and exhaust will not make a difference in running lean. The mass air flow meter measures the amount of air entering the engine and monitors accordingly, and the ebp snsr measure the amount of back pressure in the exhaust and with other sensors would also adjust accordingly. but a tune will help make sure and possibly give you more power. also from my standpoint it is really hard to tune a vehicle without a wideband. some newer cars a equipped but that will tell you where you are running now......
Old May 29, 2008 | 01:08 PM
TVT_DESIGN
Guest
Posts: n/a
The basic ECU flash leans out the fuel trim on these cars to make power, along with advancing the timing.
A CAI and exhaust will be pushing the stock injectors to the lean side. A really good breathing exhaust changes the AFR dramatically on these cars.
You will need larger injectors to see the most out of those mods and a tune. Expect about 25-30 HP more with the injectors then without.
Anthony
Kodebuster
Nov 5, 2020 04:06 PM
goodgenes79
Aug 19, 2015 10:20 PM
MAXIMUM
Aug 4, 2015 11:04 PM
grip grip
Other Cars Etc
Aug 1, 2015 09:18 PM
bradleykologek
Jul 6, 2015 02:49 PM
