stuck in 2nd gear, limp mode, need help asap
Old Oct 2, 2008 | 11:28 AM
entropy's Avatar
Default stuck in 2nd gear, limp mode, need help asap
hello all, im new to this forum, i've been reading post for a while but i recently registered... I have an 04 xfire and my car is stuck in second gear..i dunno what to do..its been parked since the weekend and i'm worried about it....i had it scanned and it was a speed sensor problem, no one has that input/output speed sensor not even the dealership..they say i have to buy a whole new valve body...i wanted advice before doing so and where can i get one that beats the dealer's 400 bucks....the speed sensor are mounted unto the valve body...i'd appreciate some comments..thanks alot guys
Old May 22, 2025 | 06:34 PM
Thegrayhemi's Avatar
Default Re: stuck in 2nd gear, limp mode, need help asap
Old May 23, 2025 | 06:12 AM
DeKalb's Avatar
Do Not go to a Chrysler or Mercedes dealer ... if you are not able to work on it your self find an independent local shop that works on Mercedes ... we need more information about the vehicle . you already said it's an 2004 , is it automatic or standard shift , coupe or roadster , and what part of the country do you live, city and state ... you can find a lot of good information here, I'm sure someone will be along shortly to point you in the right direction
Old May 23, 2025 | 11:22 AM
You can find an independent shop in your area by using this site: https://www.benzshops.com/
They probably used the wrong scanner. Chrysler has no clue what to do with these cars because they're actually Mercedes mechanically. Mercedes dealers won't touch them because they are badged as Chryslers.
If you tell us your approximate location, there might be someone experienced with Crossfires in your area.
rancher1983
Jul 2, 2015 08:09 PM
ChristineD
May 27, 2014 11:07 PM
oconnor
Jul 7, 2012 07:17 PM
entropy
Oct 13, 2008 08:04 AM
entropy
Oct 2, 2008 04:24 PM
