Oil Leak from bottom of car
Old Nov 27, 2008 | 09:29 AM
rjoyner17's Avatar
Default Oil Leak from bottom of car
So I woke up this monring and my Thanksgiving started off great by discovering my crossfire was leaking oil profusely. The car has been sitting overnight and there is a gradual dripping oil leak. There is a dark oil stain all over the bottom of the pan. The oil never leaked until I took it to Texaco last month to get an oil change. Since leaving Texaco the cars check oil light has been coming on ever since and now this morning there is oil all over the ground and the bottom of the guard or pan. What do you guys think would be the cause of this? Can I hold them liable?
Thanks!
Old Nov 27, 2008 | 09:35 AM
robby363's Avatar
Default Re: Oil Leak from bottom of car
It might be the drain plug leaking. The washer on the plug may need to be replaced.
Old Nov 27, 2008 | 10:57 AM
cought in crossfire's Avatar
I took miror , drop light there is the oil switch that is on the same side the oil plug that may have started leaking .
Old Nov 27, 2008 | 06:39 PM
CALL911's Avatar
Check the filter FIRST!!!
Old Nov 30, 2008 | 07:42 AM
Rkiser's Avatar
some oil change places are not aware that there is a o ring type washer that has to go around the plug before it is put back in. I believe this is your problem. at 100 bucks or more a pop (oil change) plus a couple thou. for a new motor. wonders never cease. There is also some o rings that go on the filter. any one of these can lead to failure. In any case, if you can prove they forgot to do something that caused failure, yes they are responsible for damages. (catch word is prove)
Old Nov 30, 2008 | 12:30 PM
So is there any word in how often these oil changes are they every 3000 miles or 7000 miles my owners manuel said like every 7000 miles . I play it safe and go 3000 miles
Old Nov 30, 2008 | 12:36 PM
acrispy1's Avatar
Its synthetic oil, 7,000 is fine.
BibaResto
Nov 7, 2016 08:21 AM
mhajek18
Dec 30, 2015 03:40 PM
Salty1974
Jun 17, 2015 07:20 AM
chuckhaze
Mar 31, 2004 03:36 PM
100smiles2thegallon
Aug 1, 2003 09:44 AM
