Help needed on Door Popper wiring
Old Dec 29, 2008 | 02:09 PM
TVT_DESIGN
Guest
Posts: n/a
Default Help needed on Door Popper wiring
I'm installing a set of Auto Loc door poppers in the car and have everything hooked up except the Negative Output from the keyless system.
I am not good with electronics and have spent the better half (I should say worse half) of a day trying to find this damn wire.
So all of you electronic geniuses out there, PLEASE HELP ME!!!
Old Dec 30, 2008 | 10:53 PM
brian_omeara07's Avatar
Default Re: Help needed on Door Popper wiring
Have you checked wiring diagrams in the manual?
Old Dec 31, 2008 | 05:57 AM
TVT_DESIGN
Guest
Posts: n/a
Yea, not the most helpful. I think I figured it out last night with a little help from Youtube.
Old Dec 31, 2008 | 08:21 AM
rcompart's Avatar
Is it a pulsed negative output? Chances are pretty good it is so all you need to do is connect the negative pulsed output from the AutoLoc to pin 86, +12VDC to pins 85 and 30 and the positive wire from the solenoid on the door popper to pin 87. You will not have anything connected to 87a so if you only find a 4 pin relay, it won't have this and are sometimes a few cents cheaper. Make sure you go with a relay large enough to handle the load the solenoid will require. Best thing to do is connect it all outside the vehicle if you can so you can diagnose what isn't workign correctly before putting it behind door panels and running wires through the boot in the door.
Hope this helps and if you have any other questions, fell free to give me a call.
Old Dec 31, 2008 | 08:50 AM
TVT_DESIGN
Guest
Posts: n/a
THat's the realy I have.
I have the HOT from the solenoid to 87, 86 and 30 are to the battery, and 85 is where I'm stumped. I don't know where the negative pulsed output is. Electrical stuff is not my forte at all...
Old Dec 31, 2008 | 08:58 AM
rcompart's Avatar
Which AutoLoc model are you using. I'm sure I either have the manual on my computer or can download it from their FTP site and I'll tell you which one it is.
Old Dec 31, 2008 | 10:06 AM
TVT_DESIGN
Guest
Posts: n/a
The SL50 kit.
I give a lot of credit to you guys that can just look at elctronics and know it, rebuilding an engine is so much easier.
Old Dec 31, 2008 | 10:36 AM
rcompart's Avatar
Originally Posted by TVT_DESIGN
The SL50 kit.
Electronics are like women, when you understand how they work and do everything right, good things happen when you turn them on.
Old Jan 13, 2009 | 11:46 PM
Haha nice...yeah i'll give props to you as well rcompart, I know speakers and amps, that's about the extent of my electronics wiring. and as for engine...well....haha, workin' on that one
that's what the forums for though right?!
gtjl
17
Jul 22, 2015 06:28 PM
RED DOG
Jul 21, 2015 07:58 AM
66L72M21
Jul 15, 2015 04:23 PM
bdh
Jul 10, 2015 11:22 AM
2005 Ragtop
Jul 9, 2015 03:16 PM
