New NeedsWings Crossfire specific Oil Catch Cans
Old Feb 9, 2009 | 11:37 PM
NeedsWings's Avatar
Default New NeedsWings Crossfire specific Oil Catch Cans
we are finishing up our batch of them this week, then they just need to be powdercoated black. we designed this in conjunction with waldig and are very pleased with the outcome (big thanks to woody for all the input). They are made out of 6061 billet aluminum, low restriction, high filtration, easy to drain, direct bolt-on kit with all hoses and fittings. we looked into using a premade catch can from another manufacturer and just making a crossfire specific bracket but found that these so called "catch cans" dont have any filtration inside them to filter the oil, lol. so we finalized on a 3 chambered design with stainless steel filtration media.
why would we need such a part?
the 2 smaller (one on each bank) valve cover ports feeding into the bottom of the throttle body are pulling oil into the intake stream tru the venturi port on the bottom of the throttle body. This is coating everything after the throttle body with oil. for those of you srt6 guys that have looked at the inside of their intercooler, air distribution ypipe or intake manifolds will know what i'm refferring to. this oil coating is a innefficiency to the cooling and flow thru the intercooler and hinders flow thru the ypipe and manifolds. the spark plugs will eventually foul as well due to this oil. in short, its crud and we don't want it.
these cans have been in testing since last fall and all revisions have been made already
ill be finalizing pricing this week but this will be a cheap and effective mod for you guys. it will work on the na xfires also, but we haven't tested on one yet to determine how much oil we will catch on them.
anyone want them coated anything other then black? i like the "blend in black" but am open to suggestions. Or we could ship them uncoated if you wanted to do your own paint scheme.
Old Feb 10, 2009 | 06:10 AM
ImportLabSRT's Avatar
Default Re: New NeedsWings Crossfire specific Oil Catch Cans
Great work Rob. Thanks for all your support for the Crossfire Community!
Old Feb 10, 2009 | 06:25 AM
waldig's Avatar
Talking Re: New NeedsWings Crossfire specific Oil Catch Cans
Here is a few shots of the prototypes that I tried to polish up for your visual amusment. The stainless mesh core really catches vapor and draining is done by hand from under the car in less than a minute. You all will enjoy the low restriction design, it is possible to blow thru it easiyl.
Enjoy Woody
Old Feb 10, 2009 | 06:44 AM
BlUEMDsrt6's Avatar
Cool, thanks Rob & Woody.
Old Feb 10, 2009 | 07:14 AM
SRT6nTulsa's Avatar
I'm interested in a black one.
Old Feb 10, 2009 | 02:37 PM
Tazz's Avatar
Interested in one for the NA -- what's involved in the installation???
Old Feb 10, 2009 | 03:54 PM
velociabstract's Avatar
I want mine in black. Pending price of course.
Les
Old Feb 10, 2009 | 04:04 PM
msheredy's Avatar
Flat or satin black for me. I know, I'm picky
Old Feb 10, 2009 | 05:42 PM
RPM's Avatar
RPM
Moderator
Good stuff Rob and Woody.
Old Feb 10, 2009 | 05:51 PM
GDC-SRT's Avatar
we are finishing up our batch of them this week, then they just need to be powdercoated black. we designed this in conjunction with waldig and are very pleased with the outcome (big thanks to woody for all the input). They are made out of 6061 billet aluminum, low restriction, high filtration, easy to drain, direct bolt-on kit with all hoses, fittings, clamps. we looked into using a premade catch can from another manufacturer and just making a crossfire specific bracket but found that these so called "catch cans" dont have any filtration inside them to filter the oil, lol. so we finalized on a 3 chambered design with stainless steel filtration media.
the 2 smaller (one on each bank) valve cover ports feeding into the bottom of the throttle body are pulling oil into the intake stream, this is coating everything after the throttle body with oil. for those of you srt6 guys that have looked at the inside of their intercooler, air distribution ypipe or intake manifolds will know what im refferring to. this oil coating is a innefficiency to the cooling and flow thru the intercooler and hinders flow thru the ypipe and manifolds. the spark plugs will eventually foul as well due to this oil. in short, its crud and we don't want it.
Really looks good!
You may want to torque those intake bolts, they look out of spec.
Old Feb 10, 2009 | 08:36 PM
RIOT's Avatar
How about getting it to match the CAI in color?
Old Feb 10, 2009 | 08:58 PM
The black is to make it blend/hide in the engine bay... but I do agree.
Old Feb 10, 2009 | 09:07 PM
NeedsWings's Avatar
either color can be done, i like the blend-in-black myself but if there is enough interest sure they could be cai silver, we would need at least 20 in silver to make it feasible to reach the powdercoaters minimum charge
ill take a look at a sample of satin black as these dont need to be semi-gloss and i think you may be correct about the satin matching the oem bracketry under the hood.
Old Feb 10, 2009 | 09:49 PM
BLKFIN's Avatar
ADDICTED TO BOOST
Very Cool! I think Black would be fine.
Old Feb 10, 2009 | 11:32 PM
ProjectMayhem's Avatar
I'll take a non-painted one .
Old Feb 11, 2009 | 10:36 PM
SRTpowa's Avatar
Black please
Old Feb 11, 2009 | 11:08 PM
Voyager's Avatar
any idea what the price is for this?
Old Feb 12, 2009 | 07:42 AM
distantpulse's Avatar
I am definately in on this.
Old Feb 12, 2009 | 09:07 AM
Bulldogger's Avatar
Do you have any idea on pricing
Old Feb 12, 2009 | 10:53 PM
hoverhog's Avatar
put me down for the black
