Easiest, cheapest way to gain noticeable performance
Hi all,
So my question is this. What is the easiest, cheapest way to get noticeable power gains for the n/a Crossfire's 3.2L without any crazy mechanical work or need for alteration to the transmission? I have an '04 alabaster coupe.
Also, does anyone know how much power the transmission can take before the internals need to be beefed up?
Finally, is there a full exhaust system out there for the Crossfire. I'm talking headers, catalytics, and muffler?
Thanks, and let the discussion begin.
Check out the TVT250 kit, sold by, you guessed it: TVT Design. He's a member of our forum and attends a lot of east coast meets. Here's his site: www.tvtdesign.com
Search a bit here in the forum and you'll see a lot of positive comments about the TVT250 kit.
Another excellent addition is a NeedsWings cold air intake. Rob (from NeedsWings) is a good guy and has been developing performance parts since back in the Neon days. www.needswings.com
Another option is an ECU tune. There are a few vendors for these, LET (www.letmotorsports.com) and InMotion (www.inmotionusa.com) are probably the most popular. I don't know what kind of gains an NA Crossfire can expect from a tune.
Past that, there are not a lot of perfomance parts for the NA Crossfires. A lot of the aftermarket performance stuff is SRT-6 only and focused on the supercharger.
As for the transmission: that depends on which tranny you have. If yours is a manual transmission, I don't know. But if it is an automatic, I believe it is the same tranny as in the SRT-6. There's a few guys here in the forums running pretty hot cars (10.x and 11.x second quarter miles) with no mods to the transmission at all. It's a very stout tranny.
If you're looking to add serious power to the NA Crossfire, there is a user here "ChuckNorris" that developed a supercharger for the NA. But he halted that project and has since started a turbo project. I believe his plan is to make a turbo kit for NA owners to buy. But that is likely several months away, if it works.
First, get a Sprint Booster - it transforms the car from feeling like a grand tourer into a motorised roller skate. Cheap and cheerful, too.
If you do decide to fit one, my advice is to forget the "use a magnet on the washer" ideas - I found this totally impossible. Instead, undo the two crosspoint screws holding the black under-dash cover nearest to the pedal box, wiggle the cover off, and then it is easy to gain access to the throttle sensor cable plug.
Will a Sprint Booster work on a manual NA? It seems like every time I read about the Sprint Boosters it is related to the automatics. I have seen manual Sprint boosters for sale on ebay, but I wasn't to sure I would get much out of one.
Also, where do you recommend purchasing a Sprint booster?
Thanks!
06 Alabaster Roadster
Thanks!
Guest
Posts: n/a
Thanks!
Thanks!
PM me if interested as we have these for sale.
Guest
Posts: n/a
Originally Posted by Skyshadow
Anyone know of a Cali based shop for ECU tuning? I'm a fan of TVT but they are way too far east for me.
Another excellent addition is a cold air intake. Rob (from NeedsWings) is a good guy and has been developing performance parts since back in the Neon days
Another option is an ECU tune. There are a few vendors for these, LET and InMotion are probably the most popular. I don't know what kind of gains an NA Crossfire can expect from a tune.
wait does a sprintbooster actually add performance? I didn't think it did... would it reduce lap times/quarter mile times?
what does it actually do?
Before you drop $300 on a sprint booster, attend a meet and drive someone's car who has one.
I wasn't planning on getting one myself. I was just checking that the sprint booster didnt actually add any performance. The guy asked for cheapest way to gain noticeable performance, and a sprint booster doesn't actually add performance...
Your pedal goes from 0-5V depending on how far you have depressed it. Full throttle = 5V.
The sprint booster resets the 0V to 2.5V so that your pedal travel is only 2.5V-5V instead of 0-5V....
better throttle response, but no actual HP gain.
Before you do anything crazy, reset the throttle-by-wire response memory ... you'll be amazed at the immediate reward. Free.
Do a search for the simple procedure and other member comments.
Regards.
Regards.
