Success with SRT wing on a Limited (electrical)
Old Mar 15, 2009 | 12:23 PM
Default Success with SRT wing on a Limited (electrical)
I fgured this warranted a new thread, if not, move it!
Once you remove your active wing assy, remove just the motor from the assy (about 5 minute job). Replace all screws/ fasteners back where they belong so if you decide to go back with the active wing, you will have all the parts.
I partially wrapped the motor in padding and installed it using wire-tyes as you can see in the pics. There are many ways to mount this, as long as the motor shaft is free it will work. I found that the motor must be connected in the circuit so the BCM can read a signal to be sure the motor is present and within working range.
Next I had to wire it so the BCM had a signal that the "up limit switch" was activated or closed. The easiest way I saw to do this was to use a Tap-it connector. It is not in the outside elements so it should be ok. I know there are better connectors. You decide how you want to do it.
**** Here is the most important part I learned and overlooked everytime ****
Once I started moving in the car to 15 mph, the motor started running. Because the BCM thinks the wing is in the UP position, it trys to lower it automatically. It will run for about 20 seconds then stop, and you get the flashing light. Well I stopped the car, turned it off and restarted. I hit the 'manual up switch' for the wing and the light never came on again. Now the BCM is fooled into thinking the driver wants the wing up always and it is getting that signal.
While driving, I hit the 'down' switch position, I heard the motor run, I hit the 'up' position and everything back to normal.
Now to get this thing up to 80 mph to check for the beep, but I doubt it will since it is showing no faults/flashing lights.
Any additional input would be greatly appreciated.
James
Old Mar 15, 2009 | 07:37 PM
Default Re: Success with SRT wing on a Limited (electrical)
This diagram shows both Limit Switches in one device. This is false. Each Limit Switch is seperate and on different sides of the wing gear.
Old Mar 15, 2009 | 09:30 PM
FTroopChief's Avatar
You did a nice job James. Looks good, congratulations
John P
FTroopChief
Old Mar 15, 2009 | 10:34 PM
SRT6nTulsa's Avatar
It looks good, James. I look forward to seeing it first hand at the dragon.
Old Mar 16, 2009 | 01:16 AM
amick6534's Avatar
Nice job James, Thanks!
Old Mar 18, 2009 | 06:58 PM
Michael, if you want to do this and have any questions, ask away.
James
Old Mar 19, 2009 | 05:33 AM
GDC-SRT's Avatar
Nice work around!
Old Mar 7, 2010 | 04:08 PM
ITMATRS's Avatar
Hi James,
I just bought an 04 - Red like your about a month ago and am very interested in the SRT6 fin addition. I have a few ads out looking for the fin and mounts but replies i have received are asking what seems to be insane amounts + the trade of my stock fin and motor. Can you give me a ball park of what the fin should cost?
Thanks!
Old Mar 8, 2010 | 10:37 AM
JHM2K's Avatar
Subscribing
Old Mar 8, 2010 | 11:16 AM
+fireamx's Avatar
Originally Posted by ITMATRS
Hi James,
Thanks!
Just for the record, these are fins.
Classic Car Fins Stock Photos & Vector Art : Bigstock® - Royalty Free Stock Photography
Old Mar 8, 2010 | 03:45 PM
Nice writeup James, and I am looking forward to seeing that amazing N/A - SRT red beauty again at the Dragon
Old Mar 26, 2010 | 11:02 PM
Almost 2 years like this and not a single problem. When I replaced my battery, and started the car for the first time, I heard the wing motor running. I hit the "up" button and nothing since. Perfect.
James
Old Mar 28, 2010 | 01:54 PM
ITMATRS's Avatar
Red face Re: Success with SRT wing on a Limited (electrical)
Originally Posted by +fireamx
I stand corrected, but since we're splitting hairs on terminology here, let me revise my question...
Does anyone have ball park estimates on what the SRT6 Rear Fixed Spoiler and Mounts should cost used or new?
V
V
V
Thanks!
Old Mar 28, 2010 | 02:54 PM
Good price if still available >> https://www.crossfireforum.org/forum...ing-panel.html
Thanks!
Old Mar 28, 2010 | 05:28 PM
amick6534's Avatar
Here is the price of both new parts, plus shipping costs.
OEM Catalog Item #1bx70tzzab
MSRP $1,405.00 Discount Price $941.35
SPOILER SRT6/FIXED
OEM Catalog Item #1bx73tzzab
MSRP $1,035.00 Discount Price $693.45
PLATE SPOILER BASE S
mopardiscountparts.com
amx1397
Jan 24, 2016 02:12 PM
grip grip
Other Cars Etc
Aug 1, 2015 09:18 PM
user 8202
Jul 12, 2015 10:43 AM
GWAPA
Jul 8, 2015 07:25 PM
Blackout317
Jul 7, 2015 08:38 PM
