K&N Air Filter
Old Mar 19, 2009 | 07:38 AM
spensley's Avatar
Default K&N Air Filter
Anybody have any input or preferably results on the following K&N intake on Needswings website???
http://www.needswings.com/Product.as...8-000fcebfcb60
Old Mar 19, 2009 | 07:43 AM
texas t's Avatar
Talking Re: K&N Air Filter
I put one on mine, srt 6 it fit fine!!!!!!
Old Mar 19, 2009 | 08:30 AM
spensley's Avatar
Default Re: K&N Air Filter
Any noticeable difference in anything?
What is the bracket which is referred to - is it just longer than the one supplied in the regular CAI kit?
Old Mar 19, 2009 | 09:01 AM
texas t's Avatar
I did not use a bracket. It is designed for more airflo, do not know if a different can be felt. I only had the other k&n cone on there for a day then went with the rx-2820
Old Mar 19, 2009 | 09:30 AM
N.Y.XFIRE's Avatar
IDK if neuspeed makes one for the x-fire put one in my VW has K&N filter with it....awsome check out if they make one.... again making a suggestion not saying anything bad about the x-fires just saying this product worked well for the vw and sure it would be nice compliment the x-fire... throatier sound...better acceleration!
Old Mar 19, 2009 | 10:20 AM
spensley's Avatar
Is rx-2820 which you quote in the post the actual K&N part number?
Old Mar 19, 2009 | 10:26 AM
NeedsWings's Avatar
yes it is a higher flowing filter which we were able to figure out how to fit behind the grill properly. the brackets we make are to move the p/s line so it will fit.
Old Mar 19, 2009 | 10:37 AM
spensley's Avatar
Hi Rob,
So if I purchase this filter to replace the one which came with your intake will I definately have to use the new bracket supplied?
Does this bracket just push the P/S line out of the way or is it completely relocating the P/S line (I can't see it in your pics)?
Any issues with engine temps etc due to the larger filter blocking the radiator?
I have a Limited.
Thanks.
Old Mar 19, 2009 | 10:45 AM
N.Y.XFIRE's Avatar
Originally Posted by spensley
Hi Rob,
I have a Limited.
Thanks.
A simple heat shield does work...have one on mine after driving for 60 miles i can grab the filter and not even tell the filter is sitting right next to the radiator its about 5 inches away from the motor and radiator....check out the shield neuspeed has on theres works great! might help on your heat situation (sorry you talking about engine temp just re-read)
Old Mar 19, 2009 | 01:00 PM
spensley's Avatar
I understand what heat shields do, but I'm refering to the engine/radiator temps - does the farger filter block/reduce the air flowing through the radiator therefor raising engine temps?
Old Mar 19, 2009 | 01:13 PM
Thumper SRT6's Avatar
I have this filter installed. No noticeable increase in engine temps.
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
TerryR
Dec 13, 2019 03:27 PM
jimf
Oct 10, 2015 10:22 AM
Sep 28, 2015 07:40 PM
