The Start to my Audio build
Old Apr 24, 2009 | 01:56 PM
Skyshadow's Avatar
Default The Start to my Audio build **finally done now.
Pioneer DEH-P6000UB CD Receiver
Good head unit but the controls are insanely confusing. Also, The USB port doesnt work with a Microsoft Zune.
[media]http://i199.photobucket.com/albums/aa310/huffster_2007/P4250146.jpg[/media] [media]http://i199.photobucket.com/albums/aa310/huffster_2007/P4250147.jpg[/media]
Infinity Reference 6022i 6 1/2" 2 way Speakers
Great sounding speakers... cheap too
[media]http://i199.photobucket.com/albums/aa310/huffster_2007/P4250148.jpg[/media]
This is just the start, Next I'm installing Infinity 6x9 rears and putting a Kicker sub where the OEM sub goes. I don't want a **** load of pound, just real clear good quality sound.
Old Apr 24, 2009 | 02:12 PM
faiz23's Avatar
Default Re: The Start to my Audio build
i like the head unit never heard those specific infinity but always wanted to try the kappa perfect 6.5" component. where do you plan to install the 6x9
Old Apr 24, 2009 | 04:40 PM
Skyshadow's Avatar
I plan on having custom boxes built so they will fit into the little pockets behind the wheel wells.
Old Apr 24, 2009 | 11:19 PM
Mr. F's Avatar
get a cheap thumb drive and use it instead. the Pioneers will play WAV or MP3 files from the thumb drive.
Old Apr 24, 2009 | 11:42 PM
Skyshadow's Avatar
Yea that was my fall back, But would of been nice to use all 80g's at anytime.
Old Apr 26, 2009 | 08:08 AM
ppro's Avatar
Default Start with a Plan and Read the Manual
http://i199.photobucket.com/albums/a...7/P4250146.jpg http://i199.photobucket.com/albums/a...7/P4250147.jpg
http://i199.photobucket.com/albums/a...7/P4250148.jpg
This is a good reason to read the factory owner and installation manual before purchase.
You might have dodged the bullet though. Check section 5 of the owners manual:
Using the AUX source
Up to two auxiliary devices such as VCR or portable devices (sold separately) can be connected to this unit. When connected, auxiliary devices are automatically read as AUX sources and assigned to AUX1 or AUX2. The relationship between AUX1 and AUX2 sources is explained below.
About AUX1 and AUX2
There are two methods to connect auxiliary devices to this unit.
AUX1 source:
When connecting auxiliary equipment using a stereo mini plug cable Insert the stereo mini plug into the input jack on this unit.
For more details, refer to the installation manual. (Click)
This auxiliary device is automatically set to AUX1.
AUX2 source:
When connecting auxiliary equipment using an IP-BUS-RCA Interconnector (sold separately) - Use an IP-BUS-RCA Interconnector such as the CD-RB20/CD-RB10 sold separately) to connect this unit to auxiliary equipment featuring RCA output.
For more details, refer to the IP-BUS-RCA Interconnector owner’s manual.
This auxiliary device is automatically set to AUX2. You can only make this type of connection if the auxiliary device has RCA outputs.
Selecting AUX as the source
Press SRC to select AUX as the source.
If the auxiliary setting is not turned on, AUX cannot be selected. For more details, see Switching the auxiliary setting on page 30.
Setting the AUX title
The title displayed for the AUX1 or AUX2 source can be changed.
1 After you have selected AUX as the source, use MULTI-CONTROL and select FUNCTION to display TitleInput "A".
2 Enter a title in the same way as the built-in CD player.
For details concerning operation, refer to Entering disc titles on page 18.
Using the external unit
External unit refers to a Pioneer product (such as ones available in the future) that, although incompatible as a source, enables control of basic functions with this unit. Two external units can be controlled with this unit. When two external units are connected, the external unit is automatically allocated to external unit
1 or external unit 2 by this unit.
Basic operations of the external unit are explained below. Allocated functions are different depending on the connected external unit. For details concerning functions, refer to external unit’s owner’s manual.
Selecting the external unit as the source
Press SRC to select EXTERNAL as the source.
Old Apr 26, 2009 | 09:32 AM
Skyshadow's Avatar
Are you trying to tell me that i can put a double male headphone jack in the back and run Aux? I knew that, I'm trying to make my Zune direct USB plug in to work.
Old Sep 9, 2009 | 09:18 PM
Skyshadow's Avatar
Finish of my Audio build.
Kicker Solo-Baric 12" L-5 wired to a Kicker 700.5 Amp
[media]http://i199.photobucket.com/albums/aa310/huffster_2007/P9080233.jpg[/media]
6x9 Infiniti Reference
[media]http://i199.photobucket.com/albums/aa310/huffster_2007/P9080234.jpg[/media] [media]http://i199.photobucket.com/albums/aa310/huffster_2007/P9080235.jpg[/media]
Old Sep 11, 2009 | 01:24 PM
Looks good...
I went with 2 sets of infiniti components (one in stock location and the other in factory subs position with custom mounted tweets) and 2 12" alpine type Rs and it sounds great AND pounds my head off LOL
Old Sep 11, 2009 | 02:39 PM
Skyshadow's Avatar
Yea, that little cab really channels the bass
Old Oct 6, 2009 | 10:18 AM
Caught in a Xfire's Avatar
go to logjam electronics and buy what is called a zune core. this device will solve all your problems. it makes your zune sound amazing. also check out my gallery for pics.
Old Oct 14, 2009 | 05:18 PM
LGV-XFIRE's Avatar
Default Re: The Start to my Audio build **finally done now.
I noticed that just about all of the after market head units, regardless of brand, only support ipod. It's the programming in the unit.
HiFiSoundConnection.com sells the Zune Core Pack for your car. You can get it for around $40.00. It comes with the core unit, which hooks up to the AUX port (RCA l/r/vid out) through a 3.5mm a/v jack. It also has a feature that lets you hardwire it or use the lighter adapter. You can charge AND play through the Zune plug with out having to use the headphone jack.
Old Oct 29, 2009 | 11:41 PM
amb7247's Avatar
omg that is sexy. Is that a limited crossfire? And where did you get that sub box that holds the kicker amp? That looks incredibly clean and nicely done.
Old Oct 30, 2009 | 04:09 PM
Skyshadow's Avatar
No, It's a base. Everything was custom built by a shop in Moreno Valley,CA. If you want to do something similar I'm sure a local shop could do it if you show them the pic.
Old Oct 31, 2009 | 02:32 AM
amb7247's Avatar
Sky, am I correct that you replaced the factory subs with tho e 6x9 infinity references then installed that rear kicker in that box?
Old Oct 31, 2009 | 02:14 PM
Skyshadow's Avatar
I didnt touch the factory sub area. Those 6x9 Kappas are installed in the rear side of the fenders, there is a pocket there. I can get better pics if you don't know what I'm talking about.
LE Cross
Sep 14, 2015 01:20 PM
toob
Aug 19, 2015 07:31 AM
bonitaeric
Aug 5, 2015 01:39 PM
pioneer4x4
Jul 27, 2015 02:04 PM
xzmilan
Jul 22, 2015 10:40 AM
