Zero Throttle response
Old May 10, 2009 | 11:45 PM
Hugo's Avatar
Default Zero Throttle response
Every so often my NA LTD refuses to accelerate hard. After a second or so it allows me to G E N T L Y accelerate and if I turn the car off for a minute or two all is OK
Anyone had similiar issues?
Old May 11, 2009 | 04:21 AM
Mimi05SRT6's Avatar
Default Re: Zero Throttle repsonse
Try the throttle body reset. If it doesn't work, hopefully someone on hear will chime in. Good luck!
Old May 11, 2009 | 08:24 AM
PAULW's Avatar
I had the same problem the car would go into "limp mode" just very little throttle and after turning the car off and back on it would be fine, it turned out to be the TPS.
Old May 11, 2009 | 08:43 PM
Hugo's Avatar
OK how do I do this?
TIA
Old May 11, 2009 | 08:58 PM
1. get in car, insert key 2. turn key to on but do not start 3. Hold down throttle to the floor for 5 seconds 4. Turn key to off position but do not remove key 5. wait 2 minutes for reset...you may have to try this more than once....good luck...
Old Dec 23, 2024 | 01:28 PM
Bzak1pgh's Avatar
Default Re: Zero Throttle response
I know this is old, but have u ever figured out what was causing this?When I WOT , I lose all throttle completely, but when I turn the car off then on, it comes right back...but, it won't come back if my cars moving and I put it in N and restart the car, have to come to a complete stop.
Old Dec 23, 2024 | 05:43 PM
DTMenace's Avatar
Bzak1pgh
I assume you have a SRT6, since this type of throttle response is related to the failure of the original water/fluid pumps that cool down the superchargers on the SRT6 models. The purpose of the pump is to cool down the supercharger, avoiding failure, this is heat related, causing the limp mode to avoid total failure of the supercharger/engine. The original pumps (Bosch) had a part number ending in 03. The revised Bosch pump's number is, 0 392 022 010.
This problem started in 2006/2007 and was discussed at that time.
When you turn off your engine and permit it to sit for a while, the engine cools down and the pump will work, until the next time it overheats and the pump fails again.
Buy a new pump.
Regards,
Dennis
DTMenace
BTW, using the SEARCH button at the upper right of the main page would be beneficial in solving your issues in the future
Old Dec 23, 2024 | 05:50 PM
Bzak1pgh's Avatar
[QUOTE=DTMenace;994811]Bzak1pgh
Buy a new pump.
Regards,
Dennis
DTMenace
[/QUOTE
​​I have just the 2005 Crossfire Base... and I only have to **** off my engine and fire it right back up and my throttle is back...but like I stated , for some wired reason, while moving and restarting, it doesn't work..
Old Dec 26, 2024 | 01:19 PM
zip439's Avatar
Bzak1pgh, Too many possible problems/solutions to just guess and throw parts at it. You can go to most any auto parts store and get the car scanned for free. With a diagnostic trouble code DTC you will have someplace to start making repairs. Try scanning the car as a Mercedes 2004 SLK 320. When you get the code be sure to write it down and get the exact code, not just some explanation, get the code.
Old Dec 26, 2024 | 01:58 PM
Bzak1pgh's Avatar
This is the code I got...
Old Dec 26, 2024 | 03:18 PM
zip439's Avatar
P0123 The first one listed on your screen refers to the Accelerator Pedal Position (APP); The gas pedal. It has five wires at the connector #1 is 5 volt supply, #4 & 5 are the signal wires and #3 & 6 are the grounds and they all run to the PTCM. You can check each. Procedure is in the service manuals. Most people replace the pedal. This code can cause you to lose throttle response.
The lower code P0442refers to the Evaporative Emission System. It will cause hesitation at idle or rough idle when the PTCM activates a test of the system. Not a huge problem, but can be hard to correct.
Fix the APP problem first, clear the P0442 code and hope it doesn't come back. You can drive the car with a small leak in the Evap system and see if it causes any idle problems in the future.
You have scanned the car as a SRT6, but you have a base/limited. You should scan as a SLK 320 not AMG 32; Two different engines and a few other small differences ref scanning.
Old Dec 27, 2024 | 05:08 PM
WTS's Avatar
WTS
Late into this thread, sorry, but I had a similar problem with a P0122 code and replaced the pedal assembly which fixed it. 2004 coupe NA 6-speed.
fastback
Sep 18, 2024 01:14 AM
nickwe21
Nov 11, 2023 05:06 PM
bbcentwa
Oct 11, 2022 05:50 PM
Tom3120
May 11, 2019 10:52 PM
samo59
Jun 21, 2009 08:07 AM
