radiator fan rubbing
Old Jun 6, 2009 | 08:11 PM
maznonno's Avatar
Default radiator fan rubbing
Hi all
I heard a click from the motor and was a little worried at first but come to find that when the rad fan is running it has a spot that hits the plastic shroud, anyone else with this problem? is it easy enough to take apart and dremel the offending spot down???
as always thanks for any help!!
Maz
Old Jun 6, 2009 | 09:22 PM
MikeR's Avatar
Default Re: radiator fan rubbing
The fan should not be hitting anywhere on the shroud. Something is out of line if it is. The fan comes out VERY easily and you can pull it and check it out.
Disconnect the power plug on the drivers side, near the top, on the shroud. Pull the two clips holding the shroud to the radiator, top left and right. They just pop off. Tilt fan towards engine slightly and pull up. You will have to fiddle with the hose to get it clear of them, but it just pulls straight up. Good luck.
Old Jun 6, 2009 | 10:12 PM
CALL911's Avatar
Mine actually fell off!! The car started to overheat and I took it in under warranty and the clips were gone. The fan was just laying in the engine bay!
Old Jun 7, 2009 | 06:39 AM
maznonno's Avatar
Thanks Mike for the quick responce! I'l take a look at it and see whats up!
syfi
Mar 28, 2026 04:14 PM
Valk
Jul 12, 2021 09:49 PM
paine2907
Oct 2, 2015 10:01 AM
Oct 1, 2015 01:42 AM
RiderJC
Sep 7, 2015 11:19 PM
