Leaking Oil Cap.
Old Oct 7, 2009 | 11:40 PM
Teck-9's Avatar
Default Leaking Oil Cap.
The oil cap on my engine leaks oil. I heard somewhere that there is a replacement cap that stops the leak. What should I do?
Old Oct 8, 2009 | 06:16 AM
blackxfire's Avatar
Default Re: Leaking Oil Cap.
You need to replace your filter and install the new rubber seals that come with it. If the seals are not installed correctly your oil cap will leak. Stan
Old Oct 8, 2009 | 07:20 AM
chevyboyac's Avatar
Mine is doing the same so I am doing a oil change this weekend
Old Oct 8, 2009 | 06:38 PM
Teck-9's Avatar
i figured it out. you pop out the rubber guard in the cap and turn it over to the non worn side. when that side wears too, you got to get a new cap tho
Old Oct 9, 2009 | 03:49 PM
jdokan's Avatar
every new filter comes with the replacement seals....replace the 4 seals everytime you replace the filter...
Old Oct 9, 2009 | 04:54 PM
chevyboyac's Avatar
I just replaced my oil filter and got 5 seals ...I dont know what the 5th o-ring is for but oh well lol. ALso just replaced my fuel filter.....wasnt that hard actually. No more oil leak and I have completely no idea as to what seal you are talking about that you flipped over :P LOL
Old Oct 9, 2009 | 11:25 PM
Teck-9's Avatar
the oil cap, not the one for the filter. this cap is up and to the right. it has a rubber seal in the cap.
Old Oct 22, 2009 | 11:45 AM
bobsor's Avatar
The oil cap is #15 (see http://www.oediscountparts.com/partl...ayCatalogid=0), and there is a gasket as well, #16. Hope this is what you're looking for.
Old Nov 12, 2009 | 10:23 AM
gabe74gt's Avatar
why you need to go for a replacement. cant you seal it up with some adhesive thing. that must do.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
pop49
Sep 30, 2015 11:14 AM
Sep 28, 2015 07:40 PM
