1784 vs 1786 harness for deck install which Antenna adapter
Old Oct 13, 2009 | 08:04 PM
boostwhore's Avatar
Default 1784 vs 1786 harness for deck install which Antenna adapter
Hello im wondering which harness works better. I know the 1784 with basically be double amping the factory speakers... Does it sound distorted?
The 1786 obviously just plugs into the rcas and gives a line level input similar to the factory deck.
Also does the eu10 antenna adapter have as good of reception as factory or is everyone using an amplified version. I have read through the forum but have not found answer to my question.
Old Oct 15, 2009 | 03:58 PM
boostwhore's Avatar
Default Re: 1784 vs 1786 harness for deck install which Antenna adapter
no input? One has to sound better than the other... which harness are most of you using ? How is the radio reception?
Old Oct 15, 2009 | 11:51 PM
boostwhore's Avatar
METRA 40-EU55 Antenna adapter cable VW/BMVW/BMW/European Vehicle Antenna Adapter Cable 02+; Powered antenna and newer FACRA style connector to aftermarket radioW/European Vehicle Antenna Adapter Cable 02+; Powered antenna and newer FACRA style connec
That is the correct antenna adapter to my knowledge since i have read people having worse reception with the standard antenna adapter?
Old Oct 16, 2009 | 07:03 AM
Beaner's Avatar
I know I have just the plain antenna adapter and my reception is not very good. if there is a powered one that gives better reception I would highly recomend getting that one.
Old Oct 25, 2009 | 03:58 PM
BlackCrossFire6spd's Avatar
The standard EU-10 is what you use. There is a power antenna booster in the car, but you need to connect the power antenna lead from the harness adapter to the power antenna lead of the radio. Don't confuse this with the amp turn on, there is a seperate power antenna connection.
syfi
Mar 28, 2026 04:14 PM
TerryR
Dec 13, 2019 03:27 PM
UNDER PSI
Nov 1, 2015 09:39 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
ozkancab
Sep 25, 2015 10:55 AM
