Alternator bolt loose???
Old Oct 19, 2009 | 06:08 PM
gunsofthenavarrone's Avatar
Question Alternator bolt loose???
As I was replacing my headlight bulb, I noticed the bolt holding the alternator seems to be backed out based on the smooth and shiny portion I could see and the gap. When I went to tighten it......it would not budge. At this point I'm not convinced it is loose. Is there so much tension on the belts that I would need to loosen it before attempting to tighten? or is it the way it is on all xfires? I'd hate to find out the hard way...on the freeway if it backs out all the way. Thanks
Old Oct 20, 2009 | 07:15 PM
Default Re: Alternator bolt loose???
Ok Heres a pic. If anyone could take a peek at their own and let me know if they see the same thing or is this supposed to be tightened all the way down. service manual says like 11 lbs of torque though I know I put much more than that and it didnt budge. Any help would be much appreciated!
Old Oct 20, 2009 | 07:28 PM
32krazy!'s Avatar
looked at my engine and i have a female torx bolt in that position but it isnt sticking out like your foto.
one possibilty why you cant tighten it may be due to the belt putting tension on the alternator. maybe take the belt off and see if it will move.
Old Oct 20, 2009 | 07:54 PM
chevyboyac's Avatar
This is what mine looks like. I had to take a brake from workin on my resume. And in the last pic theres another mystery crossfire owner who parts next to me hummm lol
Old Oct 20, 2009 | 08:15 PM
LantanaTX's Avatar
Your bolt is not loose. They look loose but that is how they go together. Last week I transfered my alternator to my V8 and that is exactly what they are supposed to look like.
Old Oct 21, 2009 | 10:11 AM
EXCELLENT! thanks guys! I was gearing up for loosening the belts to try and tighten. Headache and confusion averted!
Old Oct 21, 2009 | 10:34 AM
Attachment 16516
Attachment 16517
Attachment 16518
O CRAP...your's is loose too!! thanks for the pics....totally puts my mind at ease.
Old Oct 21, 2009 | 11:22 AM
maxcichon's Avatar
Guys-looks like a washer/spacer to me...
Old Oct 21, 2009 | 01:40 PM
The part you see is just a support bushing for that end of the bolt, the tightening is done at the other end of the bolts (2) using threads in the casting. The arrangement pulls the generator against the rear supports. Thats what I see anyway.
Old Oct 21, 2009 | 01:45 PM
The part you see is just a support for that end of the bolt, the tightening is done at the other end of the bolts (2) using nuts. The arrangement pulls the generator against the rear supports.
Generator? Someone is showing his age.
Old Oct 21, 2009 | 05:52 PM
Not quite, I used the word as used in the official shop manual. I could have used alternator, but that word is missing entirely from the shop manual and I would not want someone to start looking for one in the manual.
I am a real dynamo when it comes to looking for answers though.
Old Oct 21, 2009 | 07:22 PM
MikeR's Avatar
180.... your still and old f@r+....
Old Oct 21, 2009 | 07:46 PM
kenng's Avatar
If this was on an aircraft, I would assume I'm looking at fore/aft spacers (shims) to ensure belt alignment (manufacturing stack tolerances could drive the alternator pulley slightly fore or aft - during engine assembly I would assume there is a belt alignment check with a method to "zero" tolerances and ensure alignment)... Just a thought.
Old Oct 21, 2009 | 08:59 PM
maxcichon's Avatar
Yep-good call.
Old Oct 21, 2009 | 10:33 PM
What you see is a bushing that fits the outside diameter of the bolt and the inside diameter of the casting, the shoulder of the bolts push against the bushings forcing the generator against the rear casting and locking it in place. Any pulley mis-alignment would be capable of being taken up by the length of belt from the idler and the water pump pulleys.
Old Jul 29, 2010 | 04:35 AM
firemen's Avatar
The tightening routine for the alternator is fairly important. The proper sequence is to adjust with the mount bolt just barely loose, then tighten the mount bolt, pivot bolt and adjustment mechanism bolt
Old Jul 29, 2010 | 05:38 AM
There is no adjustment bolt, the adjustment is the tensioner pulley.
syfi
Mar 28, 2026 04:14 PM
blackpepper
Oct 4, 2017 06:09 AM
Sep 26, 2015 10:21 PM
Sep 25, 2015 07:46 AM
Abaton6
Sep 24, 2015 10:14 PM
