Another Engine Noise
Old Oct 25, 2009 | 03:53 PM
BlackCrossFire6spd's Avatar
Default Another Engine Noise
I have searched the forums for a while, and all I can find are people with "ticking" noises under the hood. I have what sounds like a whinning sound that is comming from some rotating piece on the engine as it increases pitch with engine speed. I'm assuming it's from a pully bearing, but which one? I've heard many mercedes engines that make the same noise, but it's getting kinda loud. I have a 05, manual NA with 48,000 miles. Has anyone else had a similar problem? Any helpful advice?
Old Oct 27, 2009 | 04:08 PM
bugmanfast4's Avatar
Default Re: Another Engine Noise
you know I have that noise myself. It comes from the alt. it is a high output alt. if it gets to noisy you need to have it checked. I am a tech. and have checked mine and it seems fine for now but you never know.
Old Oct 27, 2009 | 06:05 PM
Problem solved, it was the idler pully. THe bearing was shot so the pully was loose and making the odd noise. The part was $32 from Mercedes, and it took 15 minutes to replace. Now the engine purrs like it did the day I took it home from the dealer (with the exception of the exhaust, which sounds more prominant now that the engine is quieter)
IGot2P
Jul 26, 2025 12:40 PM
massanu
18
Nov 23, 2015 08:52 AM
velociabstract
15
Sep 7, 2015 03:43 PM
yorxs
Aug 18, 2015 07:21 PM
Tp'sfury
Aug 13, 2015 08:20 PM
