Oil capacity question
Old Nov 20, 2009 | 09:18 PM
Bladerunner4114's Avatar
Default Oil capacity question
Specs all say Xfires take 8.5 qts oil; but at 8 qts dipstick reads full. Query whether or not to add that extra .5 qt. --B4114
Old Nov 20, 2009 | 09:27 PM
MikeR's Avatar
Default Re: Oil capacity question
When the dipstick says full, stop adding.....
Old Nov 20, 2009 | 11:41 PM
If you were to take a brand new engine, add oil to the full level on the dip stick, then run the engine and recheck the oil level, I am sure that you would have to add oil to bring it back up to the full level again.
Not all of the oil would drain when the plug was removed as oil would be adhering to the inside of the engine, inside the oil ways, hydraulic lifters and in small puddles throughout the engine etc. I am sure that a pint of oil could easily be left inside the engine in this manner.
You may put in 8.5 qts at first but you would not put that in the next time.
Old Nov 21, 2009 | 02:06 AM
8 Quarts fills mine perfectly every time and I change my own oil.
Mobil1 0W40
Old Nov 21, 2009 | 07:22 PM
Mimi05SRT6's Avatar
1 thing people are overlooking is that the oil filter is on top of the engine, meaning that when the car is off, it all drains down. So it may show as full with only 8 quarts with the filter being empty.
Old Nov 21, 2009 | 11:02 PM
As the oil is checked with the engine stationary all the time using the dipstick this really proves nothing. I stand by my statement in post #3 but specifically add oil trapped in the filter. The line from the oil pump I believe is fitted with a one-way valve, so oil past that point is trapped except oil that is subject to gravity which pulls it beyond the filter and joins the oil subject to the leak down. As air has to enter the lines to replace the oil, the leak down of oil could take a very long time and not be apparent at the dipstick until much much later.
Valk
Jun 22, 2025 09:15 PM
4drturbo
21
Nov 12, 2018 04:50 PM
stlas69
Sep 14, 2015 06:45 PM
lazorouss
Sep 11, 2015 09:16 AM
PNA
Sep 5, 2015 02:20 PM
