oil temp sending unit help
Old Dec 10, 2009 | 04:10 PM
green-ghost's Avatar
Default oil temp sending unit help
Im planning out some extra gauges, a pillar, and have a question regarding an oil pressure sending unit. Ive had one of these in the past on my Z3 and it was simply a oil pan drain plug with a sender built into it. Im doing a search and find senders that Im unaware of or if they would work in our engine (size etc)
heres the link
Amazon.com: oil temp sender: Automotive+
also, any info as to which wire to splice into on the oxygen sensor to activate a cyberdyne a/f gauge?
Thanks
Curtis
Old Dec 11, 2009 | 09:42 PM
Default Re: oil temp sending unit help
Im zeroing in on an oil temp sending unit but am unable to find the correct thread/size for it. Ive searched the service repair manual with no results. I found this bolt is the correct replacement fromAuto parts wharehouse, part number W0133-1643669.
2004-2005 Chrysler Crossfire - Febi Oil Drain Plug
Im looking at this sending unit
from egauges thats m14x 1.5 but there's also one thats m16x1.5 (that doesnt appear to come with the brass o ring)
Temperature Senders: 300 Farenheit / 150 Celsius - VDO Ohm Range - egauges.com
can anyone tell me what size and/or thread I need?
Old Dec 11, 2009 | 10:06 PM
magneticred's Avatar
As I understand it, our drain plug is M14 X 1.5, length 24mm.
MERCEDES BENZ Oil Drain Plug 111 997 0330 Oil Drain Plug picture Yiparts.com
Old Dec 11, 2009 | 10:46 PM
I am considering an oil PRESSURE gauge. Turns out, there is a plug in the near bottom of the oil filter casting just for this!
This will be the easiest oil pressure gauge installation I have ever done!
Old Dec 11, 2009 | 11:31 PM
MikeR's Avatar
I have an oil pressure gauge and sending unit from JR Industries. I am making a fitting to hook up in the factory test point. The fitting will come out between the pulleys and the sending unit will fill nicely.
The test point is a 12x1.5 thread. And you need a standoff to get it outside the pulleys so you can mount the sending unit.
Old Dec 12, 2009 | 09:01 AM
Yes, I remember seeing that when I was perusing thru the repair manual. Would that be a simular sending unit, I mean, would you just remove that plug and install a sender?
Old Dec 12, 2009 | 10:57 AM
MikeR's Avatar
There is not much room between the pulleys where the plug is. And you would have to find a sending unit that is 12x1.5 thread.
Old Dec 12, 2009 | 08:31 PM
TVT_DESIGN
Guest
Posts: n/a
Do it first, this is one of the most difficult oil pressure hook ups we've ever done. We've done it on 3 cars and it is extremely not just a plug and go set up.
Old Dec 13, 2009 | 12:50 PM
((EDIT: This is in response to several posts/comments/questions in this thread.))
ANY time I can add one WITHOUT laying under the vehicle, getting crap in my face as I mess around with my hands above me - is an easy day!!!
I had not planned to simply plug the sending unit in - as has been pointed out, there is not enough clearance for that.
My thought was to install a fitting and run tubing up to a foot away and connect the sending unit to the tubing. What has slowed me down is trying to make up my mind WHERE the actual gauge will go. THAT is potentially the hard part!
I am torn between the desire for the gauge and the desire to keep the interior "factory".
Really don't know what to do there. But when I do it, (and I know I eventually will), I will come back with pictures, etc.
Old Dec 13, 2009 | 01:01 PM
MikeR's Avatar
pizzaguy, my gauges are all installed(since last summer). I have just been trying to resolve the sending unit. I finally got out the Miller tool for measuring oil pressure and found out where it plugs in. I can make a fitting to duplicate the tool and mount the sending unit and then just wire the gauge to it.
Old Dec 13, 2009 | 01:04 PM
Where are the gauges?? A pod on the windshield pillar?
Old Dec 13, 2009 | 06:20 PM
MikeR's Avatar
Yes, I have the JR triple pillar pod with the AFR, Boost and Oil pressure gauges. You can see it in my gallery.
Old Dec 13, 2009 | 06:59 PM
heres the link
Thanks
Curtis
Oops, sorry I ment oil temp sending unit Ive ordered it along with a VDO cockpit royale oil temp and voltmeter. Thanks everyone for your help
Old Dec 14, 2009 | 06:27 PM
MikeR's Avatar
I was trying to upload a pic of the Miller oil pressure adapter, but the gallery is still giving error 127 and not loading pics.......
Old Dec 14, 2009 | 09:27 PM
Me too!!! Im going nuts trying to figure out how to upload pics!!!
Old Dec 14, 2009 | 09:29 PM
rcompart's Avatar
ImageShack® - Image Hosting is your friend.
minimayhem
16
Aug 23, 2016 07:47 AM
amx1397
Oct 2, 2015 05:20 PM
Oct 1, 2015 01:42 AM
Sep 28, 2015 07:40 PM
stlas69
Sep 14, 2015 06:45 PM
