quick ? about using a jack on my car
Old Dec 16, 2009 | 09:38 PM
ssdark1's Avatar
Default quick ? about using a jack on my car
i plan on changing my oil for the first time this wkend and wanted to know if there is any reason to not put the jack in the middle front of the car instead of jacking up one side, putting a jack stand in place and then jacking up the other side? seems like it would be easier to only have to jack it up in one spot rather than two.
Old Dec 16, 2009 | 09:44 PM
Default Re: quick ? about using a jack on my car
Sorry I can't answer you question because I have never tried it. The belly pan may get in the way. If the crossmember seems strong enough, I don't see why you couldn't.
I made a set of ramps years ago out of 2x8 boards. One longer than the next, nailed together, 3 high. That is more than enough room to reach the oil plug. Much easier and safer.
Good luck, James
Old Dec 16, 2009 | 09:53 PM
I did my first oil change last month with no ramps. Just used a rachet to remove the four screws holding the cover on the bottom, then a bigger rachet on the drain plug. Reaching the rear two took some effort, but it was not all that hard to do.
My drain pan fit under the car, no problem!
Old Dec 16, 2009 | 09:56 PM
tighed1's Avatar
Without going out into the cold (63*) and checking I'd say no.
First off you can't see any crossmembers with the belly pan in the way so you would have to take that off first.
Then you would have to have a loooow profile jack.
And it would have to be pretty looong to reach in far enough.
I think...
Old Dec 16, 2009 | 09:59 PM
tighed1's Avatar
I'd also say you need to get under there anyway and get close and personal with yer ride.
It'll give you a chance to get familiar with the car and to inspect things.
Old Dec 17, 2009 | 08:12 PM
ssdark1's Avatar
thanks for the replies....i like the idea of making ramps with the boards, think ill give that a try. thanks.
Old Dec 17, 2009 | 08:14 PM
70GT6's Avatar
Originally Posted by tighed1
Without going out into the cold (63*) ...
Funny......REAL funny.
victorlautreamont
Jun 29, 2017 01:22 AM
mhajek18
Dec 30, 2015 03:40 PM
BibaResto
Jul 4, 2015 03:20 PM
Geechee1962
Jun 29, 2015 09:15 AM
adamlevy
Jun 7, 2015 08:13 PM
