Engine and Transmission weight?
Old Dec 18, 2009 | 04:37 PM
ChuckNorris's Avatar
Default Engine and Transmission weight?
Anyone know what the N/A M112 weighs, I'm guessing somewhere around 300+ pounds. Not much coming up in search, maybe i'm just blind. Need to find out the tranny weight also. Will be selling engine and transmission in January if anyone is interested(38k miles).
Old Dec 18, 2009 | 10:27 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: Engine and Transmission weight?
The long block for he M112 weighs in at 380ish. The bare block is extremely light though, maybe 50 lbs.
Old Dec 18, 2009 | 10:43 PM
Sweet, my car will be lighter after the swap.
Old Dec 19, 2009 | 05:05 AM
Juggernaut's Avatar
Whatcha swapping exactly?
Old Dec 19, 2009 | 12:45 PM
I'm still researching the exact combination but it will most likely be a Mitsu 4G64 or Hyundai 4GCS block, 1g DOHC DSM Turbo head, 1G rods, Wiseco pistons. Toyota R series manual transmission. The thought of having a powertrain in a crossfire with a huge selection of aftermarket parts may scare some of you purist and inspire you to shout Rice out of fear.
Old Dec 19, 2009 | 03:05 PM
spotsbimmer's Avatar
"Ricer" heck no, not unless you put 9" diameter exhaust tips out the back, then all bets are off. Good luck with the swap.
Old Dec 19, 2009 | 04:20 PM
Jeep2Xfire's Avatar
It's funny that you're sourcing out all this "ricer" stuff. With Lantana's V8 thread, and me being a Volvo mechanic I'mm looking for a B8444S motor (Volvo, although Yamaha makes it, V8, 4.4L displacement with 4 valves per cylinder) and a TF-80SC trans, 6 speed auto, I lose my stick.... WAAAAHHHH
Old Dec 19, 2009 | 05:44 PM
The factory programming is just not user friendly. Especially when it comes to your wallet. $500 bucks for a tune is outrageous and for what? 30HP? Kudos to Lantana for getting his swap to work but I'd hate to see what it ended up costing him. After ripping up the streets in my Talon for years this makes a lot more sense than trying to put the AMG 5.5 in. High power capability, reliability, and great gas mileage.
Old Dec 19, 2009 | 06:47 PM
ZORRO's Avatar
Ford has announced a new Direct Injection V6 that makes 305 hp for the 2011 Mustang. I have no experience with direct injection (not even sure if I am spelling it right) But that is only 10 less hp than the 2010 Mustang GT makes with a V8. Hot Rod magazine Sept 09 had an interesting article on direct injection. I wonder what kind of affect it would have on our V6?
Old Dec 20, 2009 | 01:00 AM
Jeep2Xfire's Avatar
Direct injection isn't going to happen to our engines. What direct injection is when fuel is sprayed directly into the combustion chamber under a lot higher pressure to aid in atomization. Common fuel injection is when fuel is sprayed into the intake manifold, or near the vavles before the combustion chamber.
To have direct inject you'd need to rework the head to allow for the valves, fuel injector, and the spark plug
Old Dec 20, 2009 | 01:50 AM
Juggernaut's Avatar
This is probably overkill and super expensive but why not swap in an E55 Kompresssor engine.
It's been done on a C55 by DynoComp
Old Dec 20, 2009 | 12:32 PM
You could be the first! It's just a matter of time before we see this.
Old Dec 20, 2009 | 12:34 PM
DI won't happen, but in theory you could replace one of the spark plugs with an injector...
Old Dec 20, 2009 | 03:44 PM
ZORRO's Avatar
Chuck, I know this is a little off topic but thought you might find it interesting.
Direct Injection Guide - The Basics Of DI Engines Explained - Hot Rod Magazine
index.html
NeedsWings
70
Mar 24, 2023 09:48 AM
Billto
16
Sep 1, 2016 11:06 PM
chturner
Jul 24, 2015 04:47 PM
RED DOG
Jul 22, 2015 08:55 AM
