light weight battery
Old Dec 20, 2009 | 01:35 AM
NeedsWings's Avatar
Default light weight battery
We grabbed a light weight battery to throw in the car along with the wiring we have been doing. The battery is too short for the factory tie down so we ended up making a quick spacer plate out of wood for it. It came out pretty decent but we can just have them waterjet if there is more interest in a battery swap. We ended up saving 28 pounds, the new battery has 850ca and 20 amp hours. So should we cut up some more spacers from a cnc program or would everyone want to just cut their own with a circular saw and drill bit? I'm not a fan of using wood on a car but for this scenario it works well and is very cheap. If anyone has a better idea for material lets discuss.
www.needswings.com/pics/bt20installed.jpg
Old Dec 20, 2009 | 01:42 AM
Default Re: light weight battery
man, you have been around Woody too long...what battery did you use. I have been looking at the braille's...
Old Dec 20, 2009 | 01:46 AM
NeedsWings's Avatar
shuriken bt20
14 pounds, fiberglass material, no acid or liquid, sealed and can be mounted upside down if ya so wanted.
fire away with a better material, we dont want conductive metal for sure, we could do it out of acrilic or something along those lines but wood makes it so cheap we can include them for free basically.
Old Dec 20, 2009 | 03:34 AM
ProjectMayhem's Avatar
cool battery and the prices seem really decent. Would this battery hold a charge in normal daily driving or just be strictly a race day battery?
Old Dec 20, 2009 | 10:41 AM
MikeR's Avatar
Rob, you could use delrin or UHMW for your spacer. What are the dimension on the spacer? Send me a drawing.
Old Dec 20, 2009 | 10:53 AM
Moparrbust's Avatar
I just miniturized the factory battery tray so everything fit properly for the Braille I used.
Old Dec 20, 2009 | 10:56 AM
MikeR's Avatar
And now you can get to that little rubber grommet that goes into the cabin without taking the battery out!
Old Dec 20, 2009 | 11:24 AM
I like the braille set up...project...
Old Dec 20, 2009 | 11:25 AM
green-ghost's Avatar
Looks good
Old Dec 20, 2009 | 11:29 AM
MikeR's Avatar
Doc, dont chop up your battery tray....I like the smaller foot print, but would like a little cleaner tray to go with it.
Old Jan 5, 2010 | 10:13 PM
NeedsWings's Avatar
ok, new material is here and cut on the cnc program, it is a very dense rubber mat and is very cool stuff.
www.needswings.com/productimages/shurikenspacer.jpg
www.needswings.com/productimages/shurikenspacer2.jpg
www.needswings.com/productimages/shurikenwithspacer.jpg
www.needswings.com/productimages/shurikenwithspacer2.jpg
www.needswings.com/productimages/shurikenwithspacer3.jpg
i'll add the kit onto our website later tonight
Old Jan 5, 2010 | 11:03 PM
We grabbed a light weight battery to throw in the car along with the wiring we have been doing. The battery is too short for the factory tie down so we ended up making a quick spacer plate out of wood for it. It came out pretty decent but we can just have them waterjet if there is more interest in a battery swap. We ended up saving 28 pounds, the new battery has 850cca and 20 amp hours. So should we cut up some more spacers from a cnc program or would everyone want to just cut their own with a circular saw and drill bit? I'm not a fan of using wood on a car but for this scenario it works well and is very cheap. If anyone has a better idea for material lets discuss.
This battery has 850 ca not 850cca, this gives it approximately 680 cca.
The 20Ah gives it a reserve capacity of about 33 minutes.
This does not compare too well with the Interstate MTP-91 battery that is popular on this forum. This may be OK in warm States but in the colder States I would not put too much faith in it myself.
Interstate #MTP-91,
700CCA, 875CA, 72Ah, reserve capacity 120 minutes, weight 37 lbs.
The capacity of this battery is less than 1/3 the Interstate battery.
When it comes to car batteries size does count, the heavier the battery the more power it can hold.
This battery will drain quickly in the cold weather.
Old Jan 6, 2010 | 05:46 PM
NeedsWings's Avatar
thanks for the info, i edited the cca to ca in my first post.
we havent had any issues with it being 15-20f here. i surely didnt throw out my perfectly fine (although extremely heavy) stock battery, i installed it to test ourselves in the cold although i imagine customers would swap them in for racing season and swap the stock battery in for winter use (does anyone even daily drive their car in the north winter?).
Old Jan 6, 2010 | 06:01 PM
MikeR's Avatar
I do... But it mostly just rains here.....
Nice job on the spacer.... but you made me look at all the pics to find out what the two little holes were for....
Old Jan 6, 2010 | 06:29 PM
NeedsWings's Avatar
pretty slick with the holes huh?
Old Jan 6, 2010 | 07:10 PM
MikeR's Avatar
yep..... when I saw the use for them I said to myself... DUH!
Old Jan 6, 2010 | 08:11 PM
Mimi05SRT6's Avatar
I'm surprised AMX Jim hasn't chimed in yet with his custom installed small battery. He encased it in Styrofoam.
pioneer4x4
Jul 1, 2021 10:56 AM
Kodebuster
Nov 5, 2020 04:06 PM
pioneer4x4
Mar 25, 2019 10:35 AM
northwest_crossfire
May 30, 2016 05:19 PM
RiderJC
Aug 4, 2015 10:25 AM
