brake sensor replacement?
Old Mar 6, 2010 | 06:49 PM
davidjacob's Avatar
Default brake sensor replacement?
i think that my brake sensor is ruined maybe because i waited too long to change de brake pads and one of them is kind of burned up, hard to explain... can this part be changed? (sensor on brake pad)
Old Mar 6, 2010 | 07:06 PM
32krazy!'s Avatar
Default Re: brake sensor replacement?
when i bought the akebono pads new sensors were in the box. i think 2$ from the m/b dealer
Old Mar 6, 2010 | 07:07 PM
Thirteendog's Avatar
6$ from a chrysler dealer.
Old Mar 7, 2010 | 08:56 AM
bowlman169's Avatar
zipped tied and out of the way on my stoptech calipers.
Old Mar 7, 2010 | 04:56 PM
davidjacob's Avatar
thanks for the help but is there a way to et rid of the annoying light indicator in the car instead? or else ill change it cause there is one that is completely ruined .....
thanks again!
Old Mar 7, 2010 | 05:16 PM
davidjacob's Avatar
by the way, i am doubting on how i installed the sensors on the calipers... i don't know why because they used to work and now the light is on so is there a way to make the light in the dash turn off or do you have any pictures on which way the sensors are plugged? say for example that i am on the front drivers side caliper.i am facing the caliper, does the little rubber that protects the wire is supposed to be facing me or is it the plastic sensor supposed to be facing me...? I not sure i am being clear sorry for that if you have any pics or, you do understand what i trying to say, help would be appreciated!
thanks again!
bowlman169's Avatar
you will have to replace it when one breaks light goes on .
Old Mar 7, 2010 | 05:44 PM
thanks again!
Mine just snapped onto the new pad with the sensor going down the center of the pad. Let me see if I can find any pics.
Old Mar 7, 2010 | 05:45 PM
32krazy!'s Avatar
the small rubber nipple goes down between the pads and the sensor sits on the u slot
Old Mar 7, 2010 | 06:00 PM
here's a couple of pics. Hope this helps.
Old Mar 7, 2010 | 06:45 PM
davidjacob's Avatar
damn! those pins aren't there anymore.... I'll need to replace it! thanks for the help!
Old Mar 9, 2010 | 04:30 PM
Just incase you need it
Old Mar 10, 2010 | 07:54 PM
davidjacob's Avatar
thanks the tips helped a lot!
Old Mar 14, 2010 | 10:08 AM
davidjacob's Avatar
BRAKE SENSOR AT THE DEALERSHIP IN CANADA COSTS $$$$$$!!!!!! I might consider buying them in internet !
Old Mar 14, 2010 | 10:11 AM
davidjacob's Avatar
Exclamation Re: brake sensor replacement?
Can someone buy me one from the MB dealrship or chrysler dealership? I'll send you the money in buy paypal or something like that...? Please? WAYYYYY too expensive to buy it from the dealer in canada .....
Thanks!
Old Mar 14, 2010 | 05:08 PM
bmorgan's Avatar
Why not just leave them off altogether? I do not believe the dash light will come on if you do not install them. I take my wheels off often enough that I would notice the need for changing the brakes before they were completely wore out.
Old Mar 14, 2010 | 07:06 PM
32krazy!'s Avatar
pm me your address and ill mail you 1. i have a couple sitting in the garage
PNA
Nov 12, 2020 04:44 PM
Roty135
17
Oct 11, 2018 10:11 AM
Rooster98
Dec 24, 2015 10:59 AM
Rooster98
Jul 21, 2015 12:39 PM
Mark McKay
Jul 17, 2015 01:18 PM
