removing the radio trim
Old May 26, 2010 | 09:27 PM
stlouisramsfan's Avatar
Default removing the radio trim
adding the nav antenna, used the search function to no avail,
how do i remove the trim around the temp control switches/radio?
thanks
chris
Old May 26, 2010 | 11:28 PM
Default Re: removing the radio trim
thanks
chris
You pry it off very carefully, use a trim stick. Do not use a screwdriver if you value the finish.
Old May 26, 2010 | 11:36 PM
trim stick? is that in the kit from walmart? i got the top 2 tabs loose but couldnt get the others to pop out and was hoping for any tricks... got the wires today, thanks!
Old May 27, 2010 | 12:00 AM
bmorgan's Avatar
You have to take the stereo out, and then there are some screws that need to be removed. I have had mine apart a couple of times. Download the 2005 SRT-6 Service Manual from here, and you will find detailed instruction on how to remove all the pieces. https://www.crossfireforum.org/forum...ollection.html Don't worry that it is for SRT-6, as it has information for the NAs as well.
Old May 27, 2010 | 05:33 AM
kingkub57's Avatar
Yes after you remove the radio, there is two screws that hold it in place behind the radio near the top of the panel just below the a/c vent, then it should just pop off.
Old May 27, 2010 | 05:48 AM
The screws.
A trim stick is a wood or plastic prying tool.
Old May 27, 2010 | 07:39 AM
Thanks guys, didn't see the 2 screws where the radio is...
onehundred80
Aug 6, 2016 12:03 PM
smokey847
Nov 12, 2015 11:54 PM
Reliableron
Oct 17, 2015 10:19 PM
55chevy
Sep 13, 2015 07:38 PM
jaesa
Sep 7, 2015 01:50 PM
