Armor All Wheel protectant?
Old Jun 18, 2010 | 08:52 AM
racer inc's Avatar
Default Armor All Wheel protectant?
Has any one tried the new Armor All Wheel portectant? Does it work? If it works 1/2 they say is might be worth it. Theses SRT wheels are a chore.
Old Jun 18, 2010 | 09:00 AM
IBLUBYU's Avatar
Default Re: Armor All Wheel portectant?
This was just written up a day of two ago and it was favorable. search it to read.
Sorry .... can't do a "linky" to the product, but other post has it.
Search ....... WHAT BRAKE DUST?
Old Jun 18, 2010 | 11:52 AM
patpur's Avatar
Senior Member/Moderator
Default Re: Armor All Wheel protectant?
Brake dust is a PIA but I don't think any kind of wheel gunk is your answer. There are two things you can do. 1 is a set of Rotex Gold pads or similar type brake pads. They cut way down on the brake dust and will end a lot of that issue. The other part of it is properly cleaning your wheels. I have a rat tail brush that is around a foot long, it works on just about any wheel, including the PIA Srt wheels. Its important to get the back of the wheel clean as well as the front and with this brush you can do that easily each time you wash your car. A lot of dust/dirt collects behind the wheel spokes and makes its way to the front of the wheel. Every so often I even pull my wheels and clean thoroughly and polish the back side of the wheel. The wheel brush is available from Solo Horton Brushes. They are on the web. You can buy 3-4 of them for under $25.
Pat
Old Jun 19, 2010 | 06:41 AM
racer inc's Avatar
Thanks for the info. I was at the store and there are 2 products out (armorall + eagle one) The armorall was 8.50 and the E1 was on sale @$3.99. I pincked up the E1 product. I will post back how it works. I still have 3/4 on the org pads and waiting to replace w/ a up graded pad. thanks for the info.
Old Jun 22, 2010 | 11:25 PM
Montana Crossfire's Avatar
I have heard that the Armorall product actually does work.
Why would you grab the cheap one (Eagle One)? If there is something magical in the Armorall like it nearly claims, don't you think you're going to have to spend a whole $8.50 for it????? I guess you're lucky they didn't have any in the 99cent bin!
Old Jun 23, 2010 | 12:30 AM
Rapps's Avatar
Is this your rat tail brush?
http://www.solobrushes.com/Family.asp?FamilyID=114&Cat1ID=9&Cat2ID=26
Ideal for reaching through tight holes or grooves and cleaning automobile wheels. Generous quantity of white tampico is tightly held by twisted wire with wood handle. Tampico is tapered from 2 7/8 to 1 1/4 inch diameter at tip. Overall length is 15 inches.
Discount Per Size: 1 Dozen-10%, 3 Dozen-15%, 6 Dozen-20%
987 Spoke Brush Item Price Ea. #987 $3.78
Old Jun 23, 2010 | 02:05 AM
SRT SIX's Avatar
I did a write up in https://www.crossfireforum.org/forum...tml#post499162
I drove 1800 miles from SoCal to St Louis for the Crossfires Across America event and there was only minor dirt/dust build up on the front wheels of my SRT6. They were still mostly silver when I arrived. Close to the same as the residue on the rear wheels (light residue).
I followed the directions carefully. Clean the wheels throroughly (I use a cloth and an inexpensive sponge brush) You have to spray the entire wheel (both sides of the spokes etc.) then let the wheels sit and dry for at least an hour (actually, I let it sit over night).
When you do wipe the wheels, you WILL wipe off the protectant and need to reapply, but this stuff really does work.
Old Jun 23, 2010 | 10:24 AM
patpur's Avatar
Rapp's - that's the brush. I always buy 4-5 and end up giving them away. They really work well.
See you in Carlisle!
Old Jun 23, 2010 | 01:20 PM
racer inc's Avatar
Montana , Not one bit of helpful information in your whole post. Why did you waste your time to read + coment? Anyway I did not know E1 made such a product and I have had better luck with E1 over armorall products so I gave them a try.
The product sprayed on clear then turned white haze like the lable said it would. The coating did not get back to clear after drying but had a light milky haze. 3 days + 375 miles later the rims are still clean. The coating does look lighter now. From up close the rims look a little dull but from a distance they look way better with the treatment than they would all dusted up.
Old Jun 23, 2010 | 02:07 PM
Six and tighed1 arrived in St. Louis with their wheels looking very good. I will give the new Armoral product a try...SRT wheels are a PITA...
Old Jun 23, 2010 | 02:58 PM
patpur's Avatar
better than PETA doc.
Old Sep 2, 2010 | 05:53 PM
Goldwing's Avatar
Ditto on the annual removal with a good cleaning and waxing, both sides. Ditto on replacing oem brake pads with low-dust. There is very little build up and normal washing removes it.
Old Sep 12, 2010 | 10:13 AM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Ok, I have been using this product for the last couple months and have been very impressed with the results until yesterday......I washed the car and treated the wheels but then sprayed the tires with Maguires Insane Tire shine which I recently purchased. (Previously I have applied a tire dressing with a sponge). Anyway, I drove the car for about 100 miles and was dissapointed to see the wheels now covered in brake dust. More brake dust than previous periods of even a couple thousand miles. It appears that although I was very carefull to limit the tire shine overspray onto the rims, it is enevitable to happen and this is what collects the brake dust. So, for the ArmourAll Rim Protectant to work properly, I will have to go back to applying the tire dressing with a sponge.
Old Sep 12, 2010 | 11:32 AM
PNA's Avatar
PNA
I've tried the Armoral product and while it does work, you need to make sure you spray evenly and completely. If you miss portions of the wheel, you actually have brake dust migrate towards the untreated sections. While I think it does work and may help retard the brake dust collection, to me it's not worth the price. I just clean my front wheels more regularly (these are alot easier than the wheels on my Bonneville).
As for the better fix --- I'd go with what others on the forum have suggested with regard to the type of brake pads that can help.
TerryR
Dec 13, 2019 03:27 PM
Darryl Camisa
Oct 7, 2015 07:10 AM
Oct 1, 2015 01:42 AM
Mackel
Sep 29, 2015 02:41 PM
ritous1
Sep 26, 2015 01:27 PM
