Removing center console
Old Mar 15, 2004 | 04:48 PM
Tdancer2's Avatar
Default Removing center console
Ok guys, I had a goof up with the cup holder this weekend. I managed to punch a hole in my beverage thus spilling all the contents. None of it made it into the cabin... so it must have all disappeared into the console.
Has anyone taken the console apart before, and if so, where is the best place to start? Can this be easily done in a couple of hours
Thanks! ops:
Old Mar 15, 2004 | 08:37 PM
Jamikest's Avatar
Default
De-trimming the interior is not a small task in this car. If you don't have above average mechanical skills, I would suggest bringing it in to have it done. There are electronics (yaw sensor.. etc for tractions control) under the console... so I would recommend cleaning it out.
Old Mar 15, 2004 | 10:42 PM
AZ Outlaws's Avatar
Default
Just an idea... whatever was spilled will have most likely dried by the time the car can be taken to the shop. If things are still working as advertised I'd let it go as is. (Superglue the cup holder closed... it's worthless).
Old Mar 15, 2004 | 11:36 PM
Tdancer2's Avatar
Default
Ahh... squeaky clean.
It was an easier job than I expected. At least, lots easier than my old car. The console comes apart in pieces and they are not interconnected. This way, you don't have to start at the top and work your way down.
It was Pepsi - and everything was a little sticky. Even my shifter was starting to stick. Things look good so far - and I'll definitely think about gluing the cup holder down. It is pretty useless.
Old Mar 15, 2004 | 11:56 PM
David Burns's Avatar
Default
dunno why so many bad-mouth the cupholder... it fits the 7-11 22 oz. Thermos-made coffee cup just fine, and I NEVER leave home without a cuppa joe in my hand. Granted, I wouldn't DREAM of putting any sort of paper, plastic, or styro cup in it! <G>
Old Mar 16, 2004 | 05:10 AM
lordpercy's Avatar
Default
Pepsi! eek if that's the full fat version it will eat circuit boards!
Old Mar 16, 2004 | 10:00 AM
Tdancer2's Avatar
Default
Yeah, it was the full fat version. But I'm pretty sure I've got the situation licked now.
And I ordered the travel mug off the chrysler website. Anyone know if that will fit the cup holder?
Old Mar 16, 2004 | 11:00 AM
Reg Kittrelle's Avatar
Default
(Don't tell my wife I wrote this)...
Nissan Xterra started to balk going into gear. It got to the point where it would take 2 or 3 minutes of sawing effort to get it in gear. A little 'net research showed that there was a recall out on that problemc to the dealer it went.
Two days later the dealer called to tell it was ready for pickup. While there, the service advisor showed Lora her shifting assembly: It was a mass of dog hair and dried Coke/Pepsi. The whole thing had congealed into a yucky, glue-like mess. The advisor allowed the recall to pay for it, but noted that there was nothing wrong with it, just Lora's drinking habits and the fact that our dog throws fur like a sheep shearer.
Old Mar 16, 2004 | 11:45 AM
Gailwrath's Avatar
Default
cup holder works fine, I only use for bottled water
with a screw on cap...safety feature.
Old Mar 16, 2004 | 08:50 PM
VegasCrossfire's Avatar
Default
Originally Posted by Reg Kittrelle
(Don't tell my wife I wrote this...)
K Reg - we promise - we won't say a thing. :wink:
Old Mar 21, 2004 | 08:32 PM
glennnn's Avatar
Default Removing Center Console
When you removed the center console did you have access to the power window switches?
Old Mar 21, 2004 | 09:31 PM
AZ Outlaws's Avatar
Default
glennn,
You do not have to remove the entire center console to get at the power window switches. On the left side of the gear shift boot, pull up gently and it will come up. Then do the same for the section of console that held the boot in. It also comes up easily. Flip it over and you have access to the window switches.
Richard Myers made a post on the subject on 1-13 in this forum. He also posted a couple of pictures in his album.
Hope this helps... any more questions let me know.
Old Mar 22, 2004 | 03:43 PM
glennnn's Avatar
Default power window switches
Very good. Thanks for the info.
Old Mar 22, 2004 | 05:06 PM
Default Re: Removing Center Console
I don't get this power window switches thing. Is there something wrong with mine?
The "front" of the switch has a window icon. If I push the "front" of the switch, the windows go up. If I push the "back" of the switch, the windows go down. This feels correct to me. Am I just whacky, or are other people's cars wired different than mine?
Old Mar 22, 2004 | 06:32 PM
AZ Outlaws's Avatar
Some of the cars had the switches reversed... pushing on the top side of the switch made the windows go down. Likewise pushing on the bottom, the windows went up... which is *** backwards.
It's easy to fix yourself. Pry up the shifter boot and then pull up on the center section of the console the boot was attached to. Press the tabs on both ends of the switch and pull the switch down and out. Then the switches have to be reversed and the icon over the switch needs to be gently pried off and reinstalled after the switch was reversed. Reinstall everything and it will work the way it was supposed to...
Old Mar 22, 2004 | 08:15 PM
I see. didn't understand cars had gone out wired two different ways.
I'm glad 1) that mine are right and 2) that's it a fairly easy fix if they hadn't been.
Old Mar 25, 2004 | 09:07 AM
glennnn's Avatar
Default window switches
The power window switch operation was one of the first things I noticed about the car. Their operation is reversed from every other vehicle I've had with power windows. I guess it's a Euro thing. My hope is to pop the switches out of the settings and just turn them around. That was the reason for asking about access.
Old Mar 25, 2004 | 12:03 PM
WesMichaels's Avatar
Default
glennn... It's not a Euro thing. Some of the early cars were wired backward. My dealer fixed mine with no problem. I had it fixed when I had it in for it's first oil change.
Old Mar 25, 2004 | 01:30 PM
glennnn's Avatar
Ok. Thanks.
I think I'll take a stab at it this weekend.
Appears fairly simple.
Old Mar 26, 2004 | 08:15 AM
Richard Myers's Avatar
Default
Take a look at my album for " how to " pictures.
