Lighted Sills on a Roadster
Old Sep 24, 2010 | 11:16 PM
jediracer's Avatar
Default Lighted Sills on a Roadster
For those with lighted sills, where did you make your power connection? The location from the directions makes it hard to access. Has anyone used wiring right behind the seat? This is a roadster. Any help will be appreciated!
James
Old Sep 24, 2010 | 11:24 PM
bmorgan's Avatar
Default Re: Lighted Sills on a Roadster
I have different door sills than you do on my Roadster, but maybe this tutorial that I did for my installation will help you out.
Old Sep 29, 2010 | 12:29 AM
jediracer's Avatar
I tried your wiring suggestion. The lights work but..........................they are on all the time; door open or closed. I was hoping for an actual wire behind the seats that actually worked off the door switches! Thanks for your suggestion though!
james
Old Sep 29, 2010 | 03:41 AM
CrossfireLTD's Avatar
Cool Re: Lighted Sills on a Roadster
If I am not mistaken the wire harness under the seats are to be used for the Mopar Illuminated Door Sills, be aware that both sills will illuminate when either door is opened.
Old Sep 29, 2010 | 07:16 AM
jediracer's Avatar
I appreciate your input. I was aware of the operation of the sills. Just trying to get the wiring issue correct. I did send Timelordz a PM with hopes that he could answer my question. I would love to be able to wire these lights from the seat area! Thanks again for your input!
James
Old Sep 29, 2010 | 08:38 AM
bmorgan's Avatar
The way that I have mine wired, they do not stay on all the time. They only come on when the door is open, and only on the side where the door is open. Are you sure that you got the right wire in the door switch?
Old Sep 29, 2010 | 12:47 PM
SNAKEWOLF's Avatar
TRY THIS https://www.crossfireforum.org/forum...r-install.html
Old Sep 29, 2010 | 06:50 PM
jediracer's Avatar
Thanks for all the help! Problem solved......lights working. BMorgan....................I used your instructions. The first time I had failed to integrate into the door switch. The red/green wire from the radio is hot all the time. It was just a matter of figuring out which wire on the door switch. I did have to create a pigtail to the other door switch because my lights only came with one ground. Thanks for the excellent help. The tghread everyone was reerring me to dealt with the installation on a coupe i think. I was waiting for a response from TimeLordZ who created the door sill change color post! Now............what else can I mess with???
wootto
U.K.
Aug 16, 2020 07:55 PM
Hoppy
Dec 7, 2018 07:36 AM
WindRestrictor
Jul 29, 2015 03:58 PM
Mark McKay
Jul 17, 2015 01:18 PM
KwehCat
Jul 16, 2015 04:48 PM
