Where should I put my Air Fuel sensor?
Old Dec 14, 2010 | 05:21 AM
kolevski's Avatar
Default Where should I put my Air Fuel sensor?
I was thinking just behind the primary cats, but on many websites it says not to put it after cats? maybe just next to the OEM sensor on the header?
where do most of you have your sensors?
Old Dec 14, 2010 | 06:18 AM
awilson40's Avatar
Default Re: Where should I put my Air Fuel sensor?
Install Pre Cat
You want to measure and adjust A/F before the cat alters the exhaust composition.
On a Turbo charged car, you also want to install after the turbo AND before the cats.
Old Dec 14, 2010 | 06:23 AM
green-ghost's Avatar
on other forums they spliced it into the 02 sensors wiring if thats ok on our cars
Old Dec 14, 2010 | 06:52 AM
kolevski's Avatar
From what I know the OEM is a narrowband, however I agree that it should be before the cat only issue is they say if you put it to close to the engine the sensor could burn out because it's to hot, what I dont understand is the stock sensor never burns out, the system I bought is an AEM and it comes with a Bosch sensor from what I know the stock sensor is a Bosch also ...hrmmmm
Old Dec 14, 2010 | 08:01 AM
awilson40's Avatar
I have had a Zeitronix Wide band for many years on my Porsche 944 Turbo with no issues.
On that car, you place the sensor down stream from the turbo due to the heat and pressures of the exhaust on the engine side of the Turbo.
I drilled and welded the sensor bung right in front of the cat.
Old Dec 14, 2010 | 09:49 AM
downwardspiral's Avatar
Definately don't put it after the cat lol, the second set of 02's are only to ensure the primary cats are working.. they aren't really tied to the fuel system.
I attached the section in the AEM instructions about mounting position.
File Type: bmp
Old Dec 14, 2010 | 06:11 PM
32krazy!'s Avatar
john theres a place between the exhaust header and the primary cat just past the flange . you will need to drop your exhaust and plug the exhaust so the filings dont drop into the cat. drill a hole and weld the bung then insert the O2 sensor
you could also unbolt the flange and slide a piece of sheetmetal in between. drill the exhaust header just before the primary O2 sensor and drill and weld the bung. then pry down on the exhaust to allow the filings to slide off the sheetmetal. thats how i did mine
Old Dec 14, 2010 | 08:28 PM
kolevski's Avatar
That's what I was thinking steve do you have any problems with to much heat on your sensor? Or do you remove it when your not watching your AFR and replace it with a bolt?
Old Dec 15, 2010 | 10:21 AM
tunaglove's Avatar
Good question, I'm going to try swapping one narrowband with a wideband. Since your wideband is even closer to the motor do you have any trouble with it?
Old Dec 15, 2010 | 04:15 PM
32krazy!'s Avatar
no problems at all. i never remove the sensor as i datalog all the time. cruisin racing or just riding around. im able to see whats going on any time i want
Old Dec 15, 2010 | 04:32 PM
rcompart's Avatar
Did this a couple years ago and the ECU freaked out. Tried different things to see if there was something special and came to the conclusion that the ME wants to see the real deal and not a generated signal. Wish it wasn't the case as the O2s on these cars are really easy to get at.
Old Dec 15, 2010 | 09:06 PM
ChuckNorris's Avatar
I ran an Innovate LM1 wideband in the stock placement and used the narrowband emulation. Worked fine for me.
Old Dec 16, 2010 | 04:40 AM
kolevski's Avatar
I unplugged one of the OEM sensors and I got a CEL straight away however the car runs perfectly, I was thinking in the meantime I can unscrew the OEM sensor and put in my AEM sensor!!!!
For the life of me I cannot unscrew the OEM sensor its so damn tight has anyone taken it off? it must have red thread locker or something
Old Dec 16, 2010 | 08:32 AM
tunaglove's Avatar
I'm going to try the PLX one. What did you use, AEM?
Old Dec 16, 2010 | 09:42 AM
rcompart's Avatar
Yeah, I used the older AEM 30-2301 wideband before they got rid of the narrowband 0-1v output.
Old Jul 14, 2011 | 03:30 PM
goodgenes79's Avatar
Damnit, I just had an O2 sensor installe and he put it after the precats, next to the stock sensor. How much of a problem will this cause me and is there a good place to route the wires through the firewall?
Old Jul 14, 2011 | 06:17 PM
waldig's Avatar
Talking Re: Where should I put my Air Fuel sensor?
I did mine per ROB just after the stocker ON THE SIDE to keep soot and water from getting into the sensor. AFter the cats is wrong to me, just saying.
https://www.crossfireforum.org/galle...edium/0282.JPG
WEEEeeeeeeeeeeeeee Woody
Old Jul 14, 2011 | 06:25 PM
velociabstract's Avatar
I have the Needswings downpipes and the O2 sensor is after the stock location, about 8" or so, before the first set of cats.
Les
Old Jul 15, 2011 | 08:15 AM
Woody, your pic shows it AFTER the cats, but you say you disagree. Is this pic of someone elses pipe (what not to do). Confused, cheers
Old Jul 15, 2011 | 12:44 PM
waldig's Avatar
Well smack me down, your right. Between the cats is where it goes, next to the factory one. You get old and you forget what you.
Yippie if's some day!!!!!!!!!!!!! ?
PNA
Nov 12, 2020 04:44 PM
JCassiW
Southeast Forum
20
Mar 3, 2019 09:43 AM
waldig
Sep 2, 2015 11:02 AM
waldig
Jul 30, 2015 07:39 PM
ja.nko
Jul 10, 2015 03:21 PM
