headlight adjustment
Old May 7, 2011 | 09:11 AM
gtrguy's Avatar
Default headlight adjustment
What is the easiest way to aim headlights. I found the large white-capped horizontal adjustment screw, but where is the the vertical adjustment located. I have looked for the leveling bubbles but cant find them.
Any help would be appreciated.
Thanks
Old May 7, 2011 | 09:22 AM
Default Re: headlight adjustment
Thanks
If you have just changed a bulb and the lights are not aimed properly and they were fine before the change, then you have put the bulb(s) in wrong. The units only use the the one screw as the projectors are preset in the units. There should be no reason to change the adjustment normally. No bubbles are on these units.
Old May 16, 2011 | 01:53 PM
Erichenderson02's Avatar
Thanks
Yeah just make sure the bulb is seated properly. If you look at the base of the bulb there should be a small square tab that sticks up. Make sure that lines up with the tab in your headlight housing and then make sure the "speed" clip is attached properly.
-Eric
Old May 16, 2011 | 02:20 PM
mdaniels4's Avatar
are both R and L controlled by the same screew adjustment? i just put slightly bigger tires on and would need to adjust the lamps up a bit
never mind, did a search and found it, which I should havee done before I posted. My bad. seems I forget sometimes that this is not a conversation going on.
Old May 16, 2011 | 02:29 PM
-Eric
If memory serves me correctly, the tab is down on the low beams and up on the high beams.
Old May 16, 2011 | 03:04 PM
I believe that is the case. I definitely agree that the lows are the opposite of the highs. And vice versa
smfrycruzr
Jul 17, 2023 05:33 PM
Franc Rauscher
May 9, 2016 12:04 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
atdavis2
Sep 21, 2015 01:25 PM
RacerXofFL
Sep 15, 2015 05:00 PM
