Reading Transmission Dipstick Tool 722.6
Old Jun 11, 2011 | 12:12 AM
syfi's Avatar
Default Reading Transmission Dipstick Tool 722.6
Good read over at BenzWorld on how to read the 722.6 Trans dipstick:
Reading Transmission Dipstick Tool 722.6 - Benzworld.org - Mercedes-Benz Discussion Forum
Old Jun 11, 2011 | 12:29 PM
IBLUBYU's Avatar
Default Re: Reading Transmission Dipstick Tool 722.6
Recently I was at a GTG where a "mechanic" was available to do some maintenance items. I had him change my oil and filter AND drain and refill my transmission. I supplied all the oils and stuff, and all he had to do was the grunt work. Previously, when I bought my xFire in March 2010, I found that the tranny fluid was really low, and I added 2 qts of Mobil1 synthetic tran oil. At that time I noticed that when the tranny shifted from 2nd to 3rd when just lightly tickling the accelerator at around 2600 RPM, I would get a low "drone" until it downshifted to 3rd. This only appeared to happen when the tran was cold.
After I had the tran fluid drained, I had the same "drone" at the 2nd to 3rd gear downshift at 2600rpm, AND again at the 3rd to 4th downshift point at about 3600 RPM. This drone only was apparent when "tickling" the accelerator, but now was louder and happened even when warm.
I checked the tranny fluid level with my "woody" dipstick and found that the fluid was way overfilled. Evidently the mechanic drained the fluid by letting it drain, and then assumed he had to add the 10 qts of proper Mopar fluid I provided. Actually by just draining the fluid, he was able to only get out about 5 to 6 qts. So in essence he overfilled the tranny by 4 to 5 qts!
Today, I used a pump out machine and got out the 4 to 5 qts, so the level in the transmission is now correct. I then took it out to road test, and found I didn't get this "drone" at both shift points when warm. I will now let the car cool down and see if it is completely gone. I hope ....... STAY TUNED .... I'll follow up
Old Jun 11, 2011 | 01:31 PM
Howard, glad to hear you got yours straightened out.
I still say that without the chart below and a scan tool to measure trans temp, it is just a guess.
Old Jun 24, 2011 | 02:23 PM
IBLUBYU's Avatar
I don't know enuff about this car to be an expert, but I'm going to theorize my situation.
Let's see what you experts might think ......
My thoughts are, the "drone" I was experiencing with my automatic (as explained in my full post 0n 6/11), has virtually disappeared. I am thinking that with the combination of improper tranny fluid level, and possibly not exactly the right type of fluid, the torque converter had a slight delay (or "hiccup" if you will) when shifting, causing the engine to rev slightly different, and tricked out the TCM, which caused the muffler system to harmonically "drone" ! I wish I knew what I was talking about technically .. LOL
rampntlion
21
Feb 11, 2019 08:18 AM
smokey847
Nov 12, 2015 11:54 PM
Oct 1, 2015 01:42 AM
rfourt
Sep 25, 2015 01:38 PM
atdavis2
Sep 21, 2015 01:25 PM
