Lower Grill Inserts
Old Jun 25, 2011 | 12:44 PM
Fast2005XFire's Avatar
Question Lower Grill Inserts
I just purchased some of the wire mesh lower grill inserts and am pretty sure they will look good once I put them on, but I can't get the OEM ones off to install the new inserts over the OEM ones. The instructions that came with them have a picture showing how you push a screwdriver through a hole in the OEM inserts and pop a clip which should release them, but I cannot seem to make that happen. Can anyone give me a hint or two on how to remove the OEM ones without destroying them??
I'm not very mechanically inclined by the way!!!!
Thanks for any help!!!
Old Jun 25, 2011 | 02:46 PM
Default Re: Lower Grill Inserts
Actually once you see how they work, you can remove them by hand.
You can use a screwdriver and simply pry to one side or the other and they will pop out. Pry at the edge. Use a plastic type screwdriver or wrap a towel around it to protect the paint.
Very simply once you see how it works. James
Old Jun 25, 2011 | 06:13 PM
Smile Re: Lower Grill Inserts
Thanks James.....the towel trick did it!!!! I got them installed and they look awesome!!!!
55chevy
Jul 22, 2024 02:31 PM
TerryR
Dec 13, 2019 03:27 PM
Oct 1, 2015 01:42 AM
maxcichon
Sep 28, 2015 07:34 AM
ayebb
Sep 18, 2015 03:35 PM
